Banks 1 and 2 running too rich? - Club Touareg Forums
post #1 of 9 Old 03-21-2012 Thread Starter
Does anyone have any idea what would cause my engine to run too rich? I keep getting these codes that the air fuel mixture is running too rich. I have changed my main fuel pump and both mass air flow sensors. The fuel pump because it gave out and the MAFs because I kept getting a reading that it was running too lean (I suppose that turned out to be because the pump was going out.)
Anyway, now I am getting a reading that both banks are running too rich. My mechanic says the fuel line pressure is perfect (58psi).
Any ideas?
Thanks.
ReyTorres is offline
post #2 of 9 Old 03-21-2012
My God,it's full of stars
siberian's Avatar
Second Vehicle: 2008 V6
Could be your O2 sensors, dirty PCV valve or cracked vacuum hose or the coolant temp sensor which determines how warm your coolant is. What codes are you getting, P0175?
siberian
siberian is offline
post #3 of 9 Old 03-21-2012 Thread Starter
These are the codes I've been getting:
MIL DTC
P0172 System Too Rich (Bank 1)
Stored Codes
P0101 Mass or Volume Air Flow A Circuit Range/Performance (Via mass air flow model and lambda control)
P010B Mass or Volume Air Flow "B" Circuit Range/Performance
P0175 System Too Rich Bank 2
P1009 Air mass meter 1/2 implausible signal from load detection
Do they make sense to you?
Thank you, by the way, for responding. It is cool to have someone to get some direction from.
post #4 of 9 Old 03-21-2012
siberian's Avatar
OK 172 and 175 are the same except they refer to each bank. Since you've replaced the MAF, I would check for a clogged or dirty PCV followed by any cracks in the vacuum hoses (bit of soapy water the length of the hose will show you of there's a leak). If all that checks out, then I would clear the codes (now that you noted them) with a VAG-COM and see if it reappears.
HTH
siberian
siberian is offline
post #5 of 9 Old 03-21-2012 Thread Starter
Thanks, Siberian. I will do this and let you know how it turned out. Again, I am grateful. Wish me luck!
Rey
post #6 of 9 Old 03-21-2012
Get this sorted as soon as you can, or your primary cats will eventually become toast.
Subscribed.
volkswagendude is offline
post #7 of 9 Old 03-21-2012 Thread Starter
thanks. I will. I hadn't thought of that.
post #8 of 9 Old 03-21-2012
siberian's Avatar
I did mention checking the O2 sensors in my first post...
siberian
siberian is offline
post #9 of 9 Old 06-08-2014
omeridian's Avatar
I hope I can get some pointers. I have been working on my V8 Treg hunting down the gremlins. Changed the PCV, replaced cracked vacuum tube behind the firewall to brake booster, changed sparkplugs, replaced both MAF. Idle seems way more stable after the above replacements but notice a little rougher when I turn off the AC. Is this normal?
No more DTC except the P1009 Air mass meter 1/2 implausible signal from load detection after three days from DTC reset. What else am I missing? o2 sensor? Coolant temp sensor? Or one more slow leak somewhere?
Any pointers is appreciated.
omeridian is offline
check engine light , running too rich
running w/o tpms macguy Brakes, Steering, Suspension, Wheels and Tires 2 11-06-2011 10:54 PM
"Mult" Fuel Trim Error, Too Lean, both banks. pfb General Maintenance & Repair 8 02-12-2011 11:51 AM
Running on a new server... Andy R Club Touareg News & Announcements 2 03-13-2009 01:45 AM
outer banks, NC ajay Touareg Sightings 0 06-04-2006 04:16 PM
2006 V8: Burning Oil & Running Rich Ross06TouaregV8 General Maintenance & Repair 3 05-29-2006 05:51 PM
