Closed Thread
Old 07-04-2008   #41
spockcat
spockcat's Avatar
Images: 15
TT 37-06-59
2004-2005 Touareg with 09D Transmission, Design Change
June 6, 2008 – REMOVED due to information no longer applies
TT 00-06-113
All Vehicles, Expired Flash Disks
June 6, 2008 – UPDATE
If, while trying to perform a Flash update, you get a display showing that the Flash disk is out of date or has expired:
- Insert that Flash disk into a computer (with CD burning capability).
- Open the disk. There are usually 2 stored files: “Data” and “Label”.
- Open the file named “Label” using the “Notepad” program.
- Change the 4-digit year in the “Label” file to a date in the future, e.g. 2025.
- Save these changes and close the “Label” file.
- Copy both the modified “Label” file and the unmodified “Data” file onto a new one time use CD.
Do not use CDRW (erasable) discs.
TT 01-08-02
All Models - Fault Code Index Numbers During Diagnosis
In some cases the index code number listed after the fault code may aid in the diagnosis path. Below is a list of current index numbers and the meaning of each:
XXXXX-001
Upper Limit exceeded
XXXXX-002
Lower Limit exceeded
XXXXX-003
Mechanical Fault
XXXXX-004
No signal/communication
XXXXX-005
no or wrong basic settings/adaptation
XXXXX-006
short to B+ (loss of ground)
XXXXX-007
Short to Ground
XXXXX-008
Implausible signal
XXXXX-009
open/short to ground
XXXXX-010
open/short to B+
XXXXX-011
Open circuit
XXXXX-012
electrical fault in circuit
XXXXX-013
check fault memory
XXXXX-014
Defective (faulty)
XXXXX-015
Cannot be checked at the moment
Don't post embarassingly huge photos, use Photo Resize Magic. Its free, quick and easy to use.
spockcat is online now
Old 3 Weeks Ago   #42
spockcat
spockcat's Avatar
Images: 15
TT 00-08-04
All Models - Warranty Part Return Suggestion
Please do not disassemble components that are subject to warranty return. Warranty parts returned to Volkswagen
of America are sent for analysis to various suppliers and laboratories. It is imperative that these parts be returned to VWoA without consequential damage from removal, disassembly, or shipping. Please return the parts in the same manner, using the shipping material and packaging that the replacement parts arrived in. Also, please include
diagnostic information such as GFF logs and a copy of the repair order with the returned part
TT 94-08-06
2007> Touareg with HID Headlamps - Vertical headlight aim control
It may be necessary to code the headlamp modules through vehicle self diagnosis. The coding may also have to be changed if one of the headlamp assemblies has been replaced. Below is current coding for the NAR market and PR
code breakdown.
PR-Number
8Q6 - headlight range adjustment, automatic/dynamic with fixed and dynamic bending light (AFS 2)
1CR - vehicle class differentiation 7L0 (Touareg)
8BC - headlight with gas discharge lamp for driving on the right (European design)
8BZ - headlight with gas discharge lamp for driving on the left (UK or Japan design)
8JD - headlight with gas discharge lamp for driving on the right (US design)
1BA/1BE - standard/sport suspension/shock absorption 1BK/1BS/2MA - 4 corner air (sport) suspension with/without el. controlled shock absorption
Closed Thread
Tech Bulletins, Recalls & General Files Available T-Reg-Gray General Touareg Discussion 2 03-27-2007 12:37 PM
wind deflectors from weather tech cptnhook Touareg Mods 2 04-01-2004 09:11 AM
Air Suspension tech question tankertoad General Touareg Discussion 1 01-24-2004 03:56 PM
Other recommended forum communities:
Cooking Forum - Airstream Trailer Forum
Sailing Forum - Aquarium & Reef Forum
Royal Forum - Volkswagen Touareg Forum
Early Retirement Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
