VW Tech Tips - Page 5 - Club Touareg Forums
Closed Thread
post #41 of 43 Old 07-04-2008 Thread Starter
spockcat's Avatar
TT 37-06-59
2004-2005 Touareg with 09D Transmission, Design Change
June 6, 2008 – REMOVED due to information no longer applies
TT 00-06-113
All Vehicles, Expired Flash Disks
June 6, 2008 – UPDATE
If, while trying to perform a Flash update, you get a display showing that the Flash disk is out of date or has expired:
- Insert that Flash disk into a computer (with CD burning capability).
- Open the disk. There are usually 2 stored files: “Data” and “Label”.
- Open the file named “Label” using the “Notepad” program.
- Change the 4-digit year in the “Label” file to a date in the future, e.g. 2025.
- Save these changes and close the “Label” file.
- Copy both the modified “Label” file and the unmodified “Data” file onto a new one time use CD.
Do not use CDRW (erasable) discs.
TT 01-08-02
All Models - Fault Code Index Numbers During Diagnosis
In some cases the index code number listed after the fault code may aid in the diagnosis path. Below is a list of current index numbers and the meaning of each:
XXXXX-001
Upper Limit exceeded
XXXXX-002
Lower Limit exceeded
XXXXX-003
Mechanical Fault
XXXXX-004
No signal/communication
XXXXX-005
no or wrong basic settings/adaptation
XXXXX-006
short to B+ (loss of ground)
XXXXX-007
Short to Ground
XXXXX-008
Implausible signal
XXXXX-009
open/short to ground
XXXXX-010
open/short to B+
XXXXX-011
Open circuit
XXXXX-012
electrical fault in circuit
XXXXX-013
check fault memory
XXXXX-014
Defective (faulty)
XXXXX-015
Cannot be checked at the moment
Touareg Audio Accessories - Keyless Start - Paddle Shift ==>
spockcat is online now
post #42 of 43 Old 07-31-2008 Thread Starter
spockcat's Avatar
TT 00-08-04
All Models - Warranty Part Return Suggestion
Please do not disassemble components that are subject to warranty return. Warranty parts returned to Volkswagen
of America are sent for analysis to various suppliers and laboratories. It is imperative that these parts be returned to VWoA without consequential damage from removal, disassembly, or shipping. Please return the parts in the same manner, using the shipping material and packaging that the replacement parts arrived in. Also, please include
diagnostic information such as GFF logs and a copy of the repair order with the returned part
TT 94-08-06
2007> Touareg with HID Headlamps - Vertical headlight aim control
It may be necessary to code the headlamp modules through vehicle self diagnosis. The coding may also have to be changed if one of the headlamp assemblies has been replaced. Below is current coding for the NAR market and PR
code breakdown.
PR-Number
8Q6 - headlight range adjustment, automatic/dynamic with fixed and dynamic bending light (AFS 2)
1CR - vehicle class differentiation 7L0 (Touareg)
8BC - headlight with gas discharge lamp for driving on the right (European design)
8BZ - headlight with gas discharge lamp for driving on the left (UK or Japan design)
8JD - headlight with gas discharge lamp for driving on the right (US design)
1BA/1BE - standard/sport suspension/shock absorption 1BK/1BS/2MA - 4 corner air (sport) suspension with/without el. controlled shock absorption
post #43 of 43 Old 12-25-2008 Thread Starter
spockcat's Avatar
TT 01-08-04
2000> All Models - Using the 5054A Wireless Transmitter for flash updates
When using a VAS 5051B or VAS 5052A tester in conjunction with a VAS 5054A wireless transmitter head for a flash procedure, please connect a USB cable between the transmitter head and the tester. This, in conjunction with a battery charger, will eliminate most errors during the flash procedure.
TT 37-06-63
2004-2007 Touareg - Gearbox DTCs
December 19, 2008 – UPDATE: Model Years 2006 and 2007 included
DTC P0753 (0025 Solenoid Valve N88 Open / Short in Address Word 02 “Gearbox Electronics” can occur on MY 2004 and certain early MY 2005 Touareg vehicles. The root cause of the complaint is that the harness is too short, causing wire strands to break internally within the harness near the T14e connector. Do NOT replace the TCM or the Valve Body for this DTC; instead, perform the following steps:
  • Disconnect the T14e connector from the transmission
  • Back out pin 1 (yellow) from the T14e connector about 12 inches above the transmission connector
  • Butt-splice a new wire from the VAS 1978 Wiring Repair Kit, ensuring an additional 1/2 inch of extra overall harness length.
  • Re-pin the wire to the T14e connector and re-attach the harness connector to the transmission
TT 01-08-05
2004> Touareg - Improper AM Radio Station Frequencies
If the AM radio stations do not tune in on exact frequencies in equal 10 kHz intervals (770 stops at 774, 830 stops at 82, it may be due to miscoding of the instrument cluster causing the unit to be set to the European AM channel scheme. To repair, re-code the instrument cluster through GFF.
Closed Thread
Tech Bulletins, Recalls & General Files Available T-Reg-Gray General Maintenance & Repair 5 04-29-2009 12:07 PM
wind deflectors from weather tech cptnhook Touareg Exterior Mods 2 04-01-2004 09:11 AM
Air Suspension tech question tankertoad General Maintenance & Repair 1 01-24-2004 03:56 PM
