TPMS disable with vagcom DIY - Touareg - Club Touareg Forums
post #1 of 12 Old 09-11-2012 Thread Starter
4ePikanini's Avatar
Touareg: 2005 R5 TDI
I just performed this on my 2005 Touareg R5 to get rid of the annoying TPMS error that keeps buzzing when you start the car - even if it is switched off via the MFI.
NB : Do this at your own risk!
1. Pull the number 24 5Amp fuse located on the left side of the vehicle for right hand drives and throw it in the ashtray as a spare fuse..
Switch the car on but don't start it.
Connect your vagcom cable and open VCDS
I used an ebay cable and VCDS version 4 . something
Use the options in VCDS to make sure you connect - see Ross-Tech for more details.
Go to "Select Control Module"
Go to "19 - CAN Gateway"
Make a note of the soft coding to be on the safe side - in my case it is 0000006.
Click on "Recode - 07"
Make sure the coding is the same as the one you noted in the above step. DO NOT change it. It stays the same. It makes the car relearn what modules are in the car and with the fuse unplugged it doesn't see the TPMS control module so disables it.
Click on "Do it!". (NB : Own risk remember)
That's it. Cycle the key Off and On. There should be no warning or icon for the TPMS in the MFI display.
If you want to get it fixed in future you can reactivate it by following these steps again but plugging in the fuse instead of unplugging it.
;D
2001 Gen3 Di-D LWB - SOLD
4ePikanini is offline
The Following User Says Thank You to 4ePikanini For This Useful Post:
Touareg112 (02-28-2017)
post #2 of 12 Old 09-11-2012
Still Plays With Cars
aircooled's Avatar
Second Vehicle: 2006 V10 TDI
Good write up, thanks!
Please read our Club Touareg
and our
aircooled is offline
post #3 of 12 Old 10-15-2012
Just did my 04; excellent write up thanks
gdahlbeck is offline
post #4 of 12 Old 10-23-2012
funk's Avatar
VCSD S/W ?
Going to try this out this weekend. Thanks for the tip!
Q: did you use the VCDS-Lite Software or full version?
funk is offline
post #5 of 12 Old 10-23-2012
It's the full version.
post #6 of 12 Old 10-10-2013
Just did this on my '04 V6 Touareg - simple, quick and easy. Thanks for the write up!
euells is offline
post #7 of 12 Old 11-10-2014
Nevadan's Avatar
TPMS delete done.
Excellent procedure! I really appreciate how simple you made it. I just did it and no longer have the error's displayed. THANK YOU!!
'10 V6 TDI Air Suspension TReg
'04 V6 3.2L gas TReg 4 corner air (sold)
'97 Passat TDI
'98 Beetle TDI
'85 Jetta Turbo Diesel
'85 Volvo 2.4 Turbo Diesel
'85 QSW will convert to 5 cyl TD
'83 Caddy getting 1.6 TD
Nevadan is offline
post #8 of 12 Old 11-15-2015
I did this and it worked great, thanks!
But I still have a small glowing TPS indicator on the dash, do you all have that too? Any ideas why?
Regards, mike
'73 911RS Clone, '08 GT3 cup
2004 Touareg V8
my racing pages -
analogmike is offline
post #9 of 12 Old 08-18-2016
can you do this on an obdeleven?
Awni321 is offline
post #10 of 12 Old 08-18-2016
The Moderator!
Yeti's Avatar
What exactly are you asking?
Yeti is online now
Possible NEW procedure to disable TPMS aircooled General Maintenance & Repair 12 12-08-2013 06:21 PM
IS IT POSSIBLE TO DISABLE THE ANNOYING TPMS? Manuel Cordero New Member Introductions 7 08-24-2012 06:15 PM
TPMS Disable with MFI? fjorge Brakes, Steering, Suspension, Wheels and Tires 12 12-21-2009 12:14 PM
VagCom in North Jersey needed - Disable TPMS jmansmann General Maintenance & Repair 0 03-22-2009 07:21 PM
TPMS disable? offroadgrey General Maintenance & Repair 4 10-21-2004 04:07 PM
