Old 07-10-2008   #1
Luzy V8
"TMPS on/off" as an option in MFI
I VAG'd my '04 V8 to have the "TMPS on/off" as an option in my MFI.
Procedure:
Start VAG-COM ==> select ==> chassis ==> 65-Tire pressure ==> coding 07 ==> In my case I changed the coding from 0211390 into 0110390 ==> Do it !
Works absolutely error free in my Touareg.
This is the backup for me when the TMPS batteries will be empty.
Further details:
VWvortex Forums: Success! TPMS (Tire pressure control system) control via VAG COM
Luzy V8 is offline   Reply With Quote
Old 07-25-2008   #2
zerokewl
zerokewl's Avatar
Speaking of which, where are the TMPS batteries located? and are they easy to change?
2004 , V6 All-options, minus 4-climatic control, minus rear view camera, minus DVD-Nav (only CD Nav), minus Adaptive headlights, minus Suspension control, minus Heated steering wheel
zerokewl is offline   Reply With Quote
Old 08-11-2008   #3
Yeti
Yeti's Avatar
Images: 4
They are located in the wheel and are easy if you have your own tire changing machine.
Old 08-12-2008   #4
Mike's Panzer
The TPMS batteries are incased in epoxy, they can't be changed. You need new sesors when they die. They should last at least 6 years. The industry is trying for 10, but not there yet.
2007 V-10 Reed Green Air Supp. Tow Pkg. Four Zone Winter Pkg. Lock Diff. Llumar tint Mud Flaps Euro Bin and Headlight switch Sirius Radio Seat covers
Mike's Panzer is offline   Reply With Quote
V8 Touareg "Anti Lock Brake Workshop?" ABS Problem PGAorBUST Problems/Bugs 4 11-30-2006 02:50 PM
Display "adjust steering wheel" and wont start... Broncrick Problems/Bugs 7 11-24-2004 11:46 AM
