T3 Transmission flush idea, with wonderful drawings. - Page 7 - Club Touareg Forums
post #61 of 131 Old 08-28-2014 Thread Starter
Originally Posted by Nordschleife View Post
Good find, Bob. Any idea what the Ravenol goes for, per liter? The cheapest OEM ATF I could find for this trans was 19.24 at vwpartscenter. If the spec on the oils is equivalent, I wonder if Toyota's ATF would be the cheapest option? But I understand where almstsobur is coming from. Piece of mind is worth something.
Also, when do you guys plan on dropping the pan and changing the filter? 100k?
Yeah, I plan to do the flush method at 100k, then the filter and magnets at the same time. I figure every 2 flushes drop the pan and do the magnets
almstsobur is offline
post #62 of 131 Old 09-18-2014
Touareg: 2006 V6
They say it is sealed for life to make sure that customer end up going in for an $8,000 transmission job or a new car. What would stearlership not do for an extra charge?
Owners, be vigilant.
konquistador
konquistador is offline
post #63 of 131 Old 09-18-2014
Nordschleife's Avatar
Touareg: 2011 V6 TDI
I know we have been talking about ATF equivalents for the Aisin 8 speed on here. I found this to be compliant with G 055 540 A2.
BG Universal ATF, part 312. If you search it, you'll find the application chart.
Retails for 13 bucks a quart on Ebay.
2011 Touareg TDI
2013 Golf TDI
Nordschleife is offline
post #64 of 131 Old 09-18-2014
For anybody following along, the product data sheet for HAVOLINEŽ SYNTHETIC ATF MULTI-VEHICLE DEXRONŽ-VI shows g 055 540 a2 compatibility as well. This can be found for 5 dollars a quart or less if you buy in bulk. I would post the PDF but not sure how to on this site. You can google the product sheet.
2011 Touareg TDI
2013 Golf TDI
post #65 of 131 Old 10-30-2014
Almstsobur, when you say to add 1/4 Liter over (which is a great idea BTW), how exactly do you do that? Once the fluid starts running clean, how do you get 1/4 L extra into the trans?
Also, once you overfill by 1/4 L, I assume you take it for a test drive to bleed the circuit, let the vehicle cool, then raise it up level, pull the plug and let the excess drain from the overfill tube? Once it stop dripping, you're at the correct level, yes?
2011 Touareg TDI
2013 Golf TDI
post #66 of 131 Old 11-03-2014 Thread Starter
It will slowly flow by gravity from the bucket into the cooler and tranny without the vehicle running. That is correct on the level checking. You want the fluid below 45C and ideally at 35C
post #67 of 131 Old 11-03-2014
Thanks, almstsobur.
2011 Touareg TDI
2013 Golf TDI
post #68 of 131 Old 11-09-2014
What is the simplest way to check ATF temperature? I have a VAG cable but wonder if that's really necessary.
2011 Touareg TDI
2013 Golf TDI
post #69 of 131 Old 11-16-2014
Slugbug's Avatar
Second Vehicle: 2005 V6
Any reason this procedure wouldn't work on an '05 VR6 Tiptronic 6spd auto transmission? I've started to collect the parts and tools. Wanted some advise before I attempt this. Also curious about heating the new fluid on the way in. I don't want to over fill the tranny.
Slugbug is offline
post #70 of 131 Old 11-16-2014
Touareg: 2006 V6
You can't overfill trans. Ehen you get there. Ill start dripping off constantly. The best way to keep track is measure what you draine. This way you will know when you are almost there when tou fill it. I have 06 v6. Haven't done it yet but that's what I learn from here. You might want to wait till the pros chime in because I don't want to create you more stress. Unless I complete it successfully myself, I will still be as doubtful and cautious as you. I
Tool wise, I almost got everything, just missing the fluids. Also, I am not quite sure abt the right tool to open both drain and fill plug. Feel free to enlighten me if you already have that figured out.
