HOW TO: Swap Red MFD for Colour MFD
83K views 60 replies 31 participants last post by  albertorivadulla24
Here is a step by step on how to do it:
Tools needed: a trim removal kit (bought mine locally for $9)
A Torx screwdriver set
Step 1: Hook up your VCDS and do a scan. Save it a note you mileage. In this case the VCDS scan read mileage as follows: Mileage: 54140km/33641miles; however the odometer display read 54145km. This leads me to believe the REAL mileage is stored somewhere other than the instrument cluster...so any scammer trying to alter mileage could in fact not do it.
Step 2:
2a.Go to address 17, click on coding, and write down your coding (1st line on the pop up that opens)
2b Still in address 17, click on adaptation, pull down "odometer" from the built in adaptation channels, click read, then make note of the "stored value" (in this case it was 5414).
Step 3:
Go to address 19, and make note of this installed modules, this is particularly important if you are installing a used cluster, as the used cluster will be set up for the options the old vehicle had and it might trigger some warnings if you don't have the module (ie: if the donor vehicle had air suspension, and yours doesn't - this will trigger a warning on your dash...you need to correct it by correcting module 19)
Step 4:
Remove the instrument cluster as per the pdf attachments.
A couple of tricks:
-Use a wide flat wedge trim removal tool for the wood trim, stick the wedge on the bottom edge of the wood and pry up, it'll come right off
-when removing the cluster shroud, the piece you are trying to pry off is the trim towards the instruments, not the short edge towards yourself. Just stick a butter knife in there, and pry down...it takes next to no force.
Step 5: replace the cluster, its simple and the whole process should take you less than 30 minutes. Follow the pdf and tricks I mentioned in step 4.
Step 6: Hook up your VCDS and perform the following functions:
-Go to address 17, click on adaptation, pull down odometer, the stored value will read 0. input the new value with your actual mileage that you recorded in step 2 (in this case 5414). Click test - your odometer will change to the new mileage (in this case 54,140km). Click SAVE
Still in address 17, go to coding, type in the coding you saved in step 2 above.
Go to address 19, ensure your modules match the checkboxes you saved in step 3.
THAT'S IT. You're done. All the key coding and immobilization functions reside in the kessy. All Touareg's have a kessy, some have a kessy that allows keyless entry/keyless start as well. But even base models have a kessy which recognizes your key/acts as immobilizer etc.
If you are using a used cluster, then you will NOT be able to set mileage using VCDS.
Can you post autoscan from this new cluster ?
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 890 K HW: 7L6 920 890 K
Component: J285 KOMBI-INST. 8429
Revision: KHH06X60
Coding: 0007301
Shop #: WSC 12345 128 36688
VCID: 4084F7001398E23
No fault code found.
major, I will post my scan tonight when I'm back home. Yes bonnet and doors go red when open.
I also changed the transmission coding so thats why you see the "P" in the upper right hand corner and it goes D1-D6 when driving...
I can't seem to get the phone menu in there though....
Coding as it sits now is 0007301, but I'll get you the full scan tonight.
I am curious to know why the heated wheel appears on the other side? I'm wondering if its cluster firmware?
HI Nickm,
My car is 2007 facelift touareg 3.6fsi with red MFD, I swap Swap Red MFD for Colour MFD(part no.7L6920885p) under your instructions. Everything is fine, except on fault code found. I cleared it, it come back again. Then i change back red MFD,fault code disappeared.How to resovle it? Thanks!
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Control Module Part Number: 03H 906 032 T HW: 03H 906 032 S
Component and/or Version: T-GP-3.6-FSI-EU4G00 0955
Software Coding: 0001175
Work Shop Code: WSC 01001 796 68472
VCID: 336ED871512E49B
1 Fault Found:
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 80568 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Absolute Pres.: 1010.0 mbar
What major said...maybe the cluster you bought has a bad oil temp guage? not sure..it doesn't have anything to do with the straight up swap. The only errors you'll get are if you ignore step 6. There is no oil temp "option"
Just change it following the above instructions. Its just the graphics that are different between MPH and KMH speedos.
You can't just change the speedometer, you need to change the whole cluster as shown above.
Step 2:
Step 3:
Step 4:
A couple of tricks:
Nickm,
What color cluster will be the rigth to install on a 2006 v6 3.2 gasoline touareg ?
thanks.
ELIOT
Nick:
After you changed the display did you loose any functionality that you had before with the Red MFD? Did you have the dealer upgrade the firmware to get the latest available features? How did know that the 7L6.920.890.K would work for your 2009?
I am considering the same upgrade but not certain of which 280km speedo to buy for my 2010.
The latest model I have found it a 7L6.920.990.__. Looked at ETKA but still confused which is the best part number to purchase and firmware upgrade to get the same menus/features.
Thanks & Cheers
Walton
Didn't lose functionality (gained some in fact). I cannot overemphasize how important it is to follow step 2 and 3 (writing down the coding). Once you swap you WILL lose all coding and your vehicle will be throwing errors and lighting up like an xmas tree, you need to recode which is an hour-ish of time with the laptop. easy to do, just a PITA....for those that have attempted to try this by skipping the writing down step, they were rewarded with a good 12 hours of experimenting to figure out what the coding should be...
On the part number, I just bought the latest version I could find. It was a pure guess since EKTA got me nowhere...a bit of a gamble I know but it paid off. ideally just buy one out of a late 09 or '10 and you should be fine.
If you are buying off german ebay ask the seller to upgrade to latest firmware (most will do it for free) and to set the mileage at "0". If they don't reset the mileage it is impossible to correct the odometer...if its at 0 you can program in correct mileage using VCDS.
hope this helps!
Reactions: simon.zhouxiao
Guys...shockingly enough I haven't tried every possible combination nor do I have every part number. You've got some guidance above so take a risk and buy something that fits your model year and see if it works.
Clearly from the photos, this was done on a T2...I suspect it would work just as well on a T1 but I haven't tried it.
Thanks for the clarification!
It wasn't really that clear to me, sorry...... I suspect for others either which is why there are so many questions about part #'s.....
A simple edit to the post title would eliminate the confusion though. Also would be great for future reference. Just some suggestions to enhance the forum a bit. This is pretty much THE source for Touareg info on the web, and most google searches point you here straightaway...
Frankly (don't take this as a personal insult please)......this forum is just a jumbled mess compared to the other VW centric sites out there. (VWVortex, Audizine, etc..) The stickies don't really provide succinct description of what lies within, and very rarely is it clear which generation of Touareg it's applicable to. Now that we're 3 generations in, I think it's something that's sorely needed around here. And the standard answer to my statement tends to be "Well, the T1's & T2's are pretty much the same..." 'pretty much' and 'exactly are' a world apart in many instances on these beasts.....
my 2cents...
Hey Guys,
I am looking at putting the color display Part # 7L6 920 990 into my 2005 4.2 V8 Touareg. Would it work as flawless as this informational guide shows it being for installation? I intend to change the CAN BUS & the stereo to the RNS 510.
Any pointers before I invest in the parts would be appreciated.
