Go Back   Club Touareg Forums > Club Touareg Technical Forums > Touareg DIY and Technical Info
Old 06-02-2009   #61
Send a message via AIM to ZippySLC
I'm just wondering how they're going to get the old plug out. The hole is completely rounded out now. (Yes, I'm an idiot.)
It has to go to the dealer anyway because I'm having them look at the transmission. Obviously, though, I'd rather do it cheaper, but doing it on the cheap kind of got me in this mess to begin with.
ZippySLC is offline   Reply With Quote
Old 06-23-2009   #62
Images: 2
A trick I have done in the past on hex bolts is to use the next size up and lightly tap it in the hole, with some finesse it usually works. Good luck with the fix.
Flatliner is offline   Reply With Quote
Old 06-25-2009   #63
It's at the dealer now. They're looking at it and "hoping" that the threads in the pan aren't stripped. I have a feeling they're looking to ding me for a new pan.
Old 06-25-2009   #64
nltomba's Avatar
then take it somewhere else first
04 V8 with all the trimmings
Need Touareg parts shipped outside the USA?
50% off fedex rates. No membership required for shipping VW Parts
www.weship-it.com
Old 07-01-2009   #65
Dealer got the plug out, no drama. $98 later the oil was changed and new bolts installed. Phew.
Old 09-11-2009   #66
Exclamation
I'll be honest, I haven't bother to look through the 7 pages of this thread, but just wanted to add an update in case someone else comes across the same issues I ran into:
1. Torx heads that I encountered were actually T-27s, not T-25s. Best to have a full set, just in case.
2. This was my first oil change on this vehicle and obviously the ass that had it before me or the VW technician he took it to didn't know what they were doing and stripped out the 6mm hex head on the oil filter's drain plug. No worries though, although a bit messier, you can just pull the entire assembly off with the 36mm socket and a flat pan beneath to get the oil that will gush from the sides into your catch-can.
Smart idea about the tin-foil, however, make sure you definitely put it around the cross-members, sway-bar, mounts and axle - especially if you have the same trouble as I did with the filter.
Also, my local dealer (Liberty - Rapid City, South Dakota) didn't have the crush washers in their computer by stock/part number. I took a gamble that paid off by rummaging through a bin of new, though unpackaged, crush washers they had in stock and matched them against a extra drain plug they had in stock.
With my unfamiliarity of this undercarriage, this took me about 2 hours - I took my time to learn this underbody well so that it should take half the time or less on the next turn in 3K miles.
Next time and perhaps on future work, I will take hi-resolution photos for everyone with my Nikon D200. I would have this time, but it took me awhile to find 0W-40 Mobil 1 Synthetic locally which put me in a time crunch with the base's auto-hobby garage when getting it up on the lift (the best/most efficient way of changing this beast's oil IMHO).
V/R
Jon
2004 Volkswagen Touareg V8
serious is offline   Reply With Quote
Old 09-11-2009   #67
Exclamation
This method didn't work in my case, there is a fairly vast difference between the 7mm and the 6mm the filter head takes. He could have gone standard measure, though I feel that's what the asshat that took mine off before did and that is how it got screwed up.
V/R
Jon
Old 10-22-2009   #68
TM,
Did you go ahead and use the Mobile1 0W40 synthetic oil. It is also the only one I could find locally that met the VW spec. Seem OK ?
Rich
saralpug is offline   Reply With Quote
Old 11-11-2009   #69
Rich,
Your question wasn't directed to me, but I wanted to reply. I have used the Mobile1 0W40 for the past 4000 miles and am preparing for my next oil change soon. No complaints at this point. I was able to find only two oils in my local stores that have the VW spec on them, Castrol Syntec SAE 0W-30(AutoZone) and Mobile1 0W40(Pep Boys, Wal Mart, Auto Zone, Advanced, and others). The standard price is $6.99/qt. Wal Mart had the Mobile1 0W40 70 cents less per quart than everyone else which is like getting 1 quart free and since I have no complaints I chose Mobile1 again.
Good luck to you.
Chicostyk is offline   Reply With Quote
Old 11-12-2009   #70
Thanks for the feedback, it's very helpful.
See ya
Rich
DIY V6 Oil Change jtb General Maintenance & Repair 11 03-30-2010 11:44 AM
Oil Change kmorrow General Maintenance & Repair 11 04-11-2007 05:15 PM
Another DIY V6 oil change Depiry General Maintenance & Repair 5 06-21-2005 04:28 PM
oil change bassbobh General Maintenance & Repair 7 05-17-2005 07:47 PM
$100 + for an oil change? fletch0776 General Maintenance & Repair 29 09-08-2004 04:08 PM
» Sponsor Links
Club Touareg on Facebook
