DIY Oil Change for 4.2L V8 - Page 2 - Club Touareg Forums
post #11 of 174 Old 01-02-2008
Mike's Panzer's Avatar
Touareg: 2007 V10 TDI
Second Vehicle: 2004 V8
NAPA Filters (Wix) offers a check service. You mail in a bottle of oil and they give you a very detailed report. We use it on all our equipment and boats. If they find metal you start planning on rebuilds. Go to the local store and ask for the oil check kit, it's a small box with little plastic bottles for the oil and mailing labels. Very complete.
2007 V-10 Reed Green Air Supp. Tow Pkg. Four Zone Winter Pkg. Lock Diff. Llumar tint Mud Flaps Euro Bin and Headlight switch Sirius Radio Seat covers
Mike's Panzer is offline
post #12 of 174 Old 01-02-2008
alboogiee's Avatar
Originally Posted by mturco View Post
... to find out if it is synthetic or not?
I had my first oil change completed at the dealer and they said they used the proper oil, but my mileage has gone from 24 on the road down to 19.
Ouch...that is quite a drop, maybe it could be somehting else too. Is this on the same tank of gas? I see you are in SacTown (and Denver), which dealer did you use? Neilo? When I lived there I would take my Touareg to Vacaville VW, Chris Wadsworth is a very helpfuladvisor, and their techs are very knowledgeable about the Touareg.
alboogiee is offline
post #13 of 174 Old 01-02-2008
Yes, Neillo. Seems like a good group there too, just not sure about their diesel service since CA doesn't allow new sales (yet).
They did a quick turnaround replacing my front drivers window from an attempted break-in, nothing taken, the window shattered but didn't break due to tinting film (which I guess I now have to remove in CA).
mturco is offline
post #14 of 174 Old 02-18-2008
Touareg: 2007 V8
Originally Posted by sitruc View Post
Try these VWvortex Forums: DIY V8 oil change **PICS**
The writeup and pics make for an EASY oil change!!
I just added a post to this DIY detailing the changes for the '07 (and later?) V-8 models.
T-Man
T-Man is offline
post #15 of 174 Old 07-30-2008
Question, Foil...
I enjoyed this post...I've changed oil in many vehicles. After getting the VW Touareg I had one of the local oil change places change my oil. I decided to change it myself this last time and found that they had forgotten to put the 'O' ring back on the filter canister before finishing the oil change.
It was not easy! They had over tightened both the filter and plug so that it was all I could do to get everything squared away, new oil and filter and clean up the mess you rightly mention!
For the first time in my life a piece of foil from the top of the container for the new oil went into the engine when I was refilling! Does anyone know if it would go directly to the oil pan and be caught in the screen/filter or possibly a bigger problem?
jag4vou is offline
post #16 of 174 Old 07-30-2008
One reason I never pour from the original container.
-- Robert King
gt40mkii is offline
post #17 of 174 Old 07-30-2008
...good idea. Definitely will go with different container...
jag4vou is offline
post #18 of 174 Old 07-30-2008
Touareg: 2007 V8
Yikes. How big of a piece, the whole thing or just a sliver? It could get stuck somewhere on the top end and block or partially block an oil return passage, but there are several so that would not be so bad; could get hung in the valve gear; if it made it to the bottom end could get stuck in the oil pump screen, which would be maybe the best outcome. I would guess that you are *probably* OK, people have dropped a lot worse down that hole and not had a problem. And I'm afraid it would cost thousands to get it out.
Good luck....
T-Man is offline
post #19 of 174 Old 07-30-2008
Preferably one with a screen in it, or pour from the original contriner through a funnel with a screen in it.
-- Robert King
gt40mkii is offline
post #20 of 174 Old 07-30-2008
Good luck....
Small...its running fine perhaps for the reasons you mention but also concerning for the reasons you mention.
I've never done something like that before (and was happy I went through the trouble of the oil change myself after finding the 'O' ring missing from the filter)....but with the foil now on most or all the containers (Mobil 1 in this case) I have to imagine it is not uncommon. I've been looking on the Mobil site to see if they have a FAQ as to the composition of the 'foil' ...perhaps it is plastic that dissolves? Anyway, a real F UP...
jag4vou is offline
DIY V6 Oil Change jtb General Maintenance & Repair 11 03-30-2010 12:44 PM
Oil Change kmorrow General Maintenance & Repair 11 04-11-2007 06:15 PM
Another DIY V6 oil change Depiry General Maintenance & Repair 5 06-21-2005 05:28 PM
oil change bassbobh General Maintenance & Repair 7 05-17-2005 08:47 PM
$100 + for an oil change? fletch0776 General Maintenance & Repair 29 09-08-2004 05:08 PM
