#1 |
Changing V6 Spark plugs
hey, just had my plugs replaced, and i thought i could share it with you.
first of all, u need to get yourself a size 16mm spark plug socket, a flat head screw ( just to help with removing the plastic covers ) 1- remove the oil cap, then gently pop up the plastic cover, and replace the cap again ( to prevent dust from going in ). 2- gently remove the plastic cover on the vertical wiring set. 3- pop up the rear plastic cover ( with the VW logo ) 4- release the spark plugs connectors ( they may be hard to pull ) then when they are all released, remove the plastic that holds the wiring from the engine, usage of screw here is very helpfull. 5- after removing the plastic, u can now pull all the wires out. 6- replace plugs, and fix again. 7- grab a very cold beer its very simple, just be carefull when removing the plastic covers, not to break them, and the wires might be little hard to pull. |
#2 |
Were you having issues, or just changing the plugs routinely? Any signficant improvement with new plugs? I am getting up there in mileage and have not swapped out the plugs yet...just curious.
#3 |
yes, there was a little delay in response to acceleration.
somehome it feels like the car is not as responsive as it was, and the idle is just not as smooth. for me it was more than 2 years, of usage, around 50,000 Km. after replacing, the response is back to normal, and the idle is very pleasing. |
#4 |
Care to share where you bought plugs, how much, and if the gap was correct out of the box? I think the V6 and V8 use the same plugs.
I'm coming up on 60k and starting to stockpile parts for the service, tyia!
2004 V8 w/ some mods |
#5 |
V6 and V8 plugs are different from one another. I got mine for my V6 from 1stVWparts for about $12 each, and they came pre-gapped in VW boxes.
Have fun! Matt
#6 |
got the replacement set from Bosch.
its the exact relpacement -ready to fix- for the NGK sparks that comes from the VW factory. its just that i like Bosch. and the price was about 50$ for the whole set from Bosch dealer. that should be 8.5$ each. |
#7 |
Thank for pix!!!! Very helpful!!!
Did anybody try Pulstar sparks??? They seem to be a little expensive. |
#8 |
Guys, I am trying to pull the coilpack but it doesn't seem to move. Is there a trick to release it?
#9 |
Bonus photo.....
#10 |
OMG!
now this is gonna hurt! sorry to see this buddy |
| Thread Tools | |
| Display Modes | |
| Spark plugs on a '04 v6? | chitown alex | General Touareg Discussion | 4 | 03-01-2008 05:46 AM |
| 40k-should I plan on coils? And, which plugs? | Vegas Matt | General Touareg Discussion | 7 | 01-15-2008 11:04 PM |
| spark plug V8 question | nltomba | General Touareg Discussion | 3 | 09-20-2007 11:12 AM |
| Changing plugs on the V6 | shockls | General Touareg Discussion | 10 | 10-24-2006 12:34 PM |
Other
Social Knowledge
