Engine Fault Workshop - R5 TDI - Club Touareg Forums
post #1 of 10 Old 05-28-2011 Thread Starter
Hoodie's Avatar
Touareg: 2011 V6 TDI
Got the following error message today while out driving - the glow plug light came on and started flashing, the message "Engine fault Workshop!" started flashing in the MFD along with a chiming sound. Came home opened the bonnet and nothing unusual visually or smell. Left the car for 5 minutes and then had another drive for about 10 minutes with no error coming up. Any suggestions as to what may be happening?
2015 V6 TDI Tungsten Silver
2014 Polo 6R 81 TSI Comfortline Silver (face lift)
2011 V6 TDI Canyon Grey - Retired
2008 TDI Shadow Blue - Retired
Hoodie is offline
post #2 of 10 Old 05-28-2011
you could do basic things like trace glow plug wires to a connector and check this... ie unplug/plug. if glow plugs are not working next cold start may see cranking for more time then you will know if glow plug(s) not working...
Current Garage:
Audi S3 Sedan 2015
MINI Cooper 2014
Triton 4x4 2014 - Jet Boat Tow Duty
1954 Beetle
P76 Yup Neil, a Leyland P76
04 R5 Egg Luxury - My Dad's Pride and Joy - For Special Occasions in his Honour
Retired Garage:
Turbo Beetle 1.8
(retired)
Beetle 2.0 IKON (retired)
2011 FJ Cruiser (retired)
09 Pajero DiD "shorty" with double D's (retired)
07 Pajero 3.2 DiD (retired)
05 R5 Egg (scrambled and retired)
matthew@f is offline
post #3 of 10 Old 05-29-2011
Have you scanned for the error code? I had that symbol when I had a shudder issue, and I was told the error code was an intermittent fault of a fuel relay (apparently, coil and fuel will throw same code), replacing the relay didn't fix my problem, I'm guessing the shudders probably shook a relay loose temporarily.
V6 TDI 4XMotion
barefoot is offline
post #4 of 10 Old 05-30-2011
Touareg: 2008 V10 TDI
Mine did this a while ago. The warning goes off when you turn off engine, only to reappear after about 20km driving. In my case it had to to with "PDF fluid". See thread on same issue on forum.
V10 MY08 Black Magic, 18" wheels with 255/60R18 Conti A/T tyres, sunroof, OEM towbar, reversing camera plus, RNS 510, leather trim, heated seats/mirrors, air suspension, black piano ins, brake contoller, UHF(Icom 440), HF (Icom 706), low range, bonnet protector, headlight protectors.
wannabe is offline
post #5 of 10 Old 07-14-2011 Thread Starter
Hoodie's Avatar
Really Good Outcome from Dealer
The car went in about 3 weeks ago for the service and to have a look at my problem. They said "fault is way down the list and we have cleared it and it has not specified what the problem is" OK took the car home and no problems until last Sunday we decided to take a drive up central coast way got onto the freeway and bing same warning came on, pulled over turned off to reset warning and continued on 2 minutes later same thing pulled over reset and started again, this happened about 5 times in total every 2 minutes all the time also going into limp home mode (we had no place to turn off or around so we had to continue on). Got to the mooney mooney bridge and we were able to turn around then the engine light came on... Headed back home with the fault still coming on every 2 minutes until we got off the freeway again. Made it back home without it going off again (engine light stayed on though).
Took it into the dealer first thing Monday morning for them to have a look at and fix, heard back Monday afternoon to advise that the DPF has blown up! They said they were approaching VW on my behalf for a Goodwill claim 3 months out of warranty. I pointed out that for the last 6 to 9 months I have reported excessive smoke and the DPF doing weird things. I said how much if I have to pay and I was advised $4,025, nurse was called and after several cardiac shocks I was revived. Found out Wednesday morning VW had agreed to cover 100% parts and 30% labour phew - $194.00 in the end.
A big thanks to VW and my dealer for coming through on this one.
Carson
Hoodie is offline
post #6 of 10 Old 07-14-2011
OILSLURPER's Avatar
Yes, VGA will look after you, post-warranty with their goodwill program (within reason) if you abide by some guidelines.
Get the services done by a VW dealer.
ANY faults/warning lights - always report them to the dealer.
Ask for "Goodwill Assistance" if you feel the problem is unexpected. The dealer should support you if the problem is genuine.
It's worked for me on the hatch struts and worked for Hoodie with the DPF. An extended warranty is not the only solution for 'freebies'.
2007
- 4xmotion 3.0 V6TDI - never missed a beat.SOLD - 04/2012
A truly great vehicle
!!!! replaced with Passat and Navara
2007 - VW Crafter 3.5 MWB 2.5 TDI (Steinbauer ECU). German build.
2006 -
VW Caddy 1.9 TDI 6-spd manual...retired. Polish build.
2009 - VW Caddy Maxi 1.9 TDI DSG, Polish build,
2011 - VW Passat 125 TDI Highline DSG..... German build. Runs on fumes.
2012 - Navara D22 2.5 TD dual cab, chipped +400nm, 3" hi-flow exhaust, 3" lift (boat tractor). Jap build.
OILSLURPER is offline
post #7 of 10 Old 02-26-2014
Touareg: 2009 V6 TDI
I have a 2009 Touareg TDI that just had the 'glow plug' symbol appear along with the "engine fault workshop" warning. Has anyone related that to just a cold start? The temps by me are in the single digits with a negative wind chill. Or have several people come to the same or similar conclusion/response from the dealer etc...?
YokoDave is offline
post #8 of 10 Old 02-26-2014
G'day
I'm curious; Hoodie, how many k's on your car? Well, on the DPF anyway...
And same question for you YokoDave....
Regards
Kevin
Kevin
99 'busa
15 'busa
and now a HQ one tonner project
kev11e is offline
post #9 of 10 Old 02-26-2014
I have 75K on mine. I actually just got it back from the dealer after getting the AdBlue (DEF or DPF) tank heater replaced. That's an entirely different story, but did more or less just happen with the severe cold we have experienced.
YokoDave is offline
post #10 of 10 Old 02-27-2014
Ozzieboy's Avatar
Hi just to let you know I had the same symbol and message come up last June just two days after buying my v10 2008 the garage topped up the adblue then it was gone
My v10 would drive for about 10 mins the message would appear along with a chime they reckon if you keep using it it will and it runs out when you stop you won't be able to restart the treg
Ozzieboy is offline
2005 Touareg V8 - Many fault codes, System Fault-Workshop smallblock VAG-COM 17 02-03-2013 02:44 PM
Engine Fault Workshop Bails General Maintenance & Repair 12 12-27-2011 03:44 AM
Engine Fault Workshop V6 TDi evaddirb Australia & New Zealand 39 01-25-2011 07:20 AM
Engine Fault Workshop V10 TDI 1oftheV10s General Maintenance & Repair 7 01-30-2009 07:19 AM
System Fault Workshop lvilletreg General Maintenance & Repair 3 05-14-2008 11:50 PM
