Camp fridge setups in T2's - Club Touareg Forums
  • 1 Post By Owen Hammond
post #1 of 9 Old 1 Week Ago Thread Starter
Hey all,
I'm currently looking around for suitable camp fridges for the back of the Treg. Looking to downsize our existing Waeco CF80 into something that will fit lengthwise in the back. Looking at specs I think the maximum Waeco may be the CFX50 (W661 x H471 x D455)
Can other members confirm what fridge model & size they have successfully mounted in the back of a T2? Looking through some threads I've only seen a handful of images. Pictures of peoples setups would be appreciated.
Cheers & thanks in advance,
Owen
Owen Hammond is offline
post #2 of 9 Old 1 Week Ago
seafarer28's Avatar
Hi Owen,
No pics I'm afraid but most of the fridges in the back of a Touareg I have seen have been an Engel MT45's.
I do have one and originally had it on a fridge slide but found that the slide took up a bit too much room so now carry it without the slide, easy to get into even for those vertically challenged so now there is an upright full size spare wheel on the other side and some useful carry space between the two where I carry a couple of plastic storage boxes.
Have you addressed the issue of a second battery to power the fridge for any extended period?
TonyB
MY08 V6TDi, Campanella White, Enhancements: RNS 510 Nav + Bluetooth, Twin Batteries, Paddle Shifters, Steinbauer Power Module, Seikel Suspension, underbody alloy protection plates, 18" Road Tyres, 17" ATM Off-road Tyres, 3 X Full Size Spares, OEM Roof Bars, OEM Tow Pack, OEM LED load Module, Red Arc Tow Pro Elite Brake Controller, Icom IC-440 UHF + Roof Mounted Antenna, Great White LED Light Bar, Brembo 6 Spot 17Z Front Brake Upgrade .
seafarer28 is offline
post #3 of 9 Old 1 Week Ago Thread Starter
Looking at 2nd battery in spare wheel well
post #4 of 9 Old 1 Week Ago
Moderator
Steve_L's Avatar
We have a Waeco CF50. Fits length ways (from back seat to tail gate) 'just'. You can remove either handle (or both) to give yourself a bit of breathing space.
Dimensions W630 x H480 x D360 mm (W760 mm with handles)
I anchor ours with a carabiner tethering strap to the handle and then the OEM anchoring point (plenty to choose from in a T2).
I also have 2nd battery under the spare 'wheel' with 2 x continuous power supply 12V sockets added to compliment the OEM 12V socket in the back.
2007 Touareg MY08 V6 TDI - Atacama Grey (Beige Trim) Tow Pack, RNS510, 9WZ, Tint, V10 Exhaust Tips, Bilstein Sports Shocks, King Springs
2010 Polo 6R (Flash Red), 77TSI, 5Dr, DSG, Sportspack, MDI, RCD510, GTI grill, 9W7
Steve_L is online now
post #5 of 9 Old 1 Week Ago
seafarer28's Avatar
Thought you may be looking at that as well as it's obviously more important than just fitting a fridge.
I have attached a couple of old pics of my set up, which will still enable the OEM spacesaver spare to sit on top if need be, however you will also need to fit (in addition to adequate sized fused cables from the start battery) a DC-DC charger to control the way the second battery is charged and isolated once the charge stops when you stop the vehicle.
TonyB
Name:	Second battery install 009 (Large).JPG
ID:	175610   Click image for larger version
post #6 of 9 Old 1 Week Ago
seafarer28's Avatar
BTW, I also have added a dedicated connector wired direct to the 12V second battery into which I plug a 80w solar panel which charges the aux battery which is running the fridge for extended periods (days) without the need for the vehicle to be turned over.
post #7 of 9 Old 1 Week Ago Thread Starter
Thanks for looking out.
Coming from the 80 series its all a new process in finding out a) whats available and more importantly b) what will actually fit when speccing up the treg for some weekend touring.
Steve_L likes this.
post #8 of 9 Old 1 Week Ago
Moderator
Steve_L's Avatar
you've come to the right area for ALL the answers.
Many of us have (in one form or another) upgraded/customised/modified our Touaregs to meet our needs and demands.
Keep asking...we're all here to help (including NoobyToogy)
post #9 of 9 Old 1 Week Ago Thread Starter
For future benefit of others - both the CFX-50 and CFX-65 Waeco/Dometic Waeco models will fit (with handles fitted) lengthwise in the back with the Cargo screen/barrier removed.
Waeco branded (old style)
CF60: W630mm x H580mm x D360mm - not tested but should fit judging by space available around CFX65
CF50: W630mm x H480mm x D360mm (including dometic CF50) - Fits as per SteveL's post
Waeco/Dometic Waeco (newer styles)
CFX65 / CFX65DZ: W725mm x H561mm x D455mm (includes handles, 661 without handles) - FITS
CFX50: W725mm x H471mm x D455mm (includes handles, 661 without handles) - FITS
Dometic Waeco CFX-50 & Dometic Waeco CFX-65 shown below.
CFX65 also shown end on.
ID:	176050   Click image for larger version
