What do u tow? Post pic of trailer. - Page 91 - Club Touareg Forums
 31Likes
post #901 of 909 Old 02-03-2017
StephPG's Avatar
My horse trailer
enem178 likes this.
StephPG is offline
post #902 of 909 Old 02-05-2017
Curious what you are using for a WD hitch, if any? We were looking at 23 FB since tongue weight was under 500, but then sat in a 23D and like it much better. But tongue weight was 720; under the 770 from earlier T-Regs but over the new 626 rating for the 2014 and later T-Regs. So just removing a couple of hundred pounds from the tongue would be perfect, but I tend to take a conservative approach to ratings and don't want Murphy's Law to make a test case for having the receiver ripped off by a WD hitch. Bought a T-Reg based on crash ratings to replace a 4Runner totaled in a head-on collision after a girl fell asleep at the wheel, and last year a drunk slammed into (and totalled) the ambulance I was about to get in and drive as a volunteer. Fortunately I can say that being scared half to death twice does not scare you completely to death. So i don't need the excitement of a catastrophic hitch failure, because half to death three times might push the limits too far.
dstaylor is offline
post #903 of 909 Old 02-05-2017
Originally Posted by iowahusker View Post
I tow an Oliver Travel Trailer--a 2016 Elite II. It weighs about 4600 lbs. dry and it usually weighs 5100-5200 lbs. loaded for travel. Towing with a 2015 Touareg TDI.
We looked at the Olivers, really nice trailers. Feels like the inside of a big sail boat inside with all the fiberglass. They put a lot of thought into the design and think they got a lot of things right.
dstaylor is offline
post #904 of 909 Old 02-05-2017
Originally Posted by i2oadi2unnei2 View Post
We finally drove our new 2016 FC 23D home this afternoon. My first biggest and heaviest tow ever and I'm glad I got this TV and she is also my first owned TDI. Of all the TV I've researched, I am very happy and confident these two will be paired for a life time of adventure
Guess checking the quote message in reply helps my comment make more sense. Newbie mistake, can't figure out how to delete other post.
dstaylor is offline
post #905 of 909 Old 02-05-2017
Spiegelglatt's Avatar
Second Vehicle: 2007 V6
Couple quick thoughts are:
Get a tongue scale. Sherline a great product for tongue scales (try looking it up). This is a great product for trailer shopping as well as for loading.
A 23' box with a tongue weight over 600 LBS seems high. Often a particular floor plan can be found by another trailer manufacturer with either light weight construction or a slightly different axel position which can change tongue weight drastically. Ultralight versus a stick and iron trailer will demonstrate this best.
There are several WD manufacturers out there, I run Eaz-Lift Elite distribution with 1,000 lbs round bars and Eaz-Lift friction sway. Works great, but I don't ream on the system to transfer a lot of weight as my older Treg has (steel) a very firm suspension that has little sag with 800 LBS on the hitch.
Your receiver will never "rip off" or "break off" the back. This has not happened to one Touareg owner that we have read of (we would know if it did). There are eight bolts with a very high strength that hold the hitch to the box frame that runs between unibody layers from front bumper to rear hitch. This steel is high strength and is designed for loads WELL over the ratings we know of (it pulled a jet for example and lived). What could happen is legal issues if it is proven that an accident was caused by overloading / unstable / blown tire for excess axel loading. Otherwise you need to just keep all axel max ratings in spec and you will be fine running 770 LBS...this is my opinion only.
Do not moving things around to "make a heavy tongue work." It is unsafe and not fun (because it will be unstable and a pain to have things like batteries and propane not be where they should). Rather shop more and look into lighter trailers. I run a 32' (overall length) bunk house with a super slide and loaded weight of 7,500 lbs and 770 lbs on the tongue. The empty statistics for the trailer were 528 lbs on the tongue and 6,000 lbs dry and 7,500 GVWR (yes I am at the limit)...but we have it loaded pretty good which is how my tongue got so heavy versus the stock dry spec. However, because I purchased light with a light unloaded tongue, I have lots of capacity to carry cast iron cooking pots, real glasses, real plates, and so forth. When we camp we miss nothing
Spiegelglatt is offline
post #906 of 909 Old 02-06-2017
Originally Posted by dstaylor View Post
. . . . . Fortunately I can say that being scared half to death twice does not scare you completely to death . . . . .
LOL!!
That's good to know!
post #907 of 909 Old 1 Day Ago
Coachman 242 RBS
2006 V8 air susp. Coachman Freedom Express 242 RBS
2blueyam likes this.
Roger
2006 Touareg V8/Air/Tow
2001 VW Golf 1.8T Sold to Good friend
Wife
2008 Audi A4 s-line
Daughter
2005 VW Jetta 2.0
Son
2003 VW Golf 2.0 wrecked again.. and totaled
now..2004 Passat 1.8T
rbgolf01 is offline
post #908 of 909 Old 1 Day Ago
2017 Escape 17B. This is the 2nd travel trailer we've had with this Touareg. This trailer is only 2,875 lbs dry and 6'4" wide. I was getting 19-20 mpg on the trip down from picking it up in Canada towing at 65 mph.
skyfree is offline
post #909 of 909 Old 1 Day Ago
47Driver's Avatar
Our rig. We moved up from the 16' hybrid, now we are running a 24' Hybrid. For a family of four, it has the greatest floor-plan. It runs about 6,800 fully loaded and 5,500 empty. We pulled her from Alabama to Banff Canada last spring break, to Nebraska last summer, and will be hauling it to Utah and Colorado this summer.
2009 VW Jetta SW TDI with MTM ECU upgrade, Koni suspension, 1/2 inch lowering, summer and winter tires and rims. Stolen by Daughter. Paid Off.
2010 VW Touareg TDI currently having surgery. DPF/EGR delete with Buzzken exhaust/resonator and stage two Malone Tune. Paid Off
2011 Audi Q7 TDI Prestige...the hottie's car! Paid Off
47Driver is offline
Post a Pic If You Have Modified Your Suspension horsepowerfarm Brakes, Steering, Suspension, Wheels and Tires 0 07-27-2010 08:32 PM
Post your favorite mud/offroad pic!! Linder Off-Roading & Towing 13 02-09-2008 06:31 PM
Can you tow another Touareg on UHaul trailer??? iceman Off-Roading & Towing 19 07-23-2007 11:15 AM
Tow hitch for bike trailer Bigs General Maintenance & Repair 0 12-03-2006 09:16 AM
Trailer Hitch (Tow Kit) Kayvon General Maintenance & Repair 2 07-12-2004 04:40 PM
