Go Back   Club Touareg Forums > Club Touareg Technical Information > Off-Roading & Towing
Old 07-23-2008   #1
Altaoatao
Images: 5
Trailer Wiring Help
I've been searching the threads and I'm still having problems figuring this out. Maybe someone can help?
I have an 08 T2 with factory hitch and wiring. While towing, I can't get the running lights, break lights or right signal to work. I am somehow getting the left turn signal, and that's it. I am towing a boat trailer with a 5 pin connector which I assume has LED lights (Not that savvy w/ this stuff). I am using the VW Touareg Hitch Wiring Socket and 7 Pin to 4/5 Pin Trailer Wiring Converter. Is there anything else I need to make this work?
The dealer has had the car for a day and can't figure it out. They are telling me to take it to a "trailer Hitch shop" which doesn't make any sense. Any advice that I can convey onto the dealership would be appreciated.
Thanks!
Adam
Altaoatao is offline   Reply With Quote
Old 07-24-2008   #2
jimandlauries04towrig
There are fixes for this,more so than when we had the problem in '04. I had to put a standard incandescent light in the trailer circuit to "trick" the Towrigs system to deliver juice to the lights. IF the system doesn't sense a draw the LEDs won't work. There are now resistor kits to fix this now. The answer is on this forum somewhere on those.
jimandlauries04towrig is offline   Reply With Quote
Old 07-28-2008   #3
Altaoatao
Images: 5
Thanks! The dealer ended up changing a fuse that was 15 amp and should have been 20 amp. This helped and got both turn signals and the break lights to work. Now I'll need to figure out how to get all of the running lights working. I'll check out your suggestion above. Thanks!
wiring trailer hitch touareg1234 Off-Roading & Towing 4 11-24-2007 05:44 PM
Trailer wiring problems Redneck Albertan Off-Roading & Towing 3 10-29-2007 07:41 PM
Trailer Wiring TDI_Guy Problems/Bugs 1 04-10-2007 06:07 PM
Trailer Wiring Harness Dave M General Touareg Discussion 1 06-12-2006 11:42 PM
Trailer Wiring menjohnson General Touareg Discussion 0 01-06-2005 01:23 PM
