SPECIAL TERRIAN LEVEL - Bypass - Club Touareg Forums
post #1 of 7 Old 11-29-2016 Thread Starter
Hi anyone know if theres anyway you can keep yr treg in the "special terrain level", without it being overridden when the car reaches 20klms ? be great to keep that clearance at higher speeds
Some of the electronics can be very restrictive
Envisage is offline
post #2 of 7 Old 11-29-2016
marshatherton's Avatar
Just for curiosities sake, why? I feel like staying in this mode for a prolonged length of time can damage the vehicle.
Sent from my XT1575 using Tapatalk
marshatherton is offline
The Following User Says Thank You to marshatherton For This Useful Post:
Envisage (12-02-2016)
post #3 of 7 Old 11-29-2016
I have not found or heard of a way to do it.
It is probably restricted because you have VERY little articulation in the suspension at that level due to the higher pressure in the airbags at that height.
And the CV joints may not appreciate working at those angles at higher velocities, but that is my personal speculation.
The only workaround that I am aware of is to adjust the overall ride height so that it sits higher than normal for a given setting. This can be done via VCDS and is documented somewhere on the web.
The Following User Says Thank You to FSJ Guy For This Useful Post:
Envisage (11-30-2016)
post #4 of 7 Old 12-02-2016 Thread Starter
Cheers, & yeah that makes sense. The extra 60mm is really handy when off roading, but being limited to 20klm p/hr limits where it can be used.
See what the VCDS throws up
Envisage is offline
post #5 of 7 Old 12-03-2016
Supporting Member
sailboart29's Avatar
Putting the biggest tires that you can allows for a couple extra inches without changing settings. It also allows you to ride a lower setting off road and keep more articulation. Dropping down at higher speeds lowers rollover risk as well. I would like to know how to make ride height changes in VCDS but despite searching periodically for months I haven't found any specific tutorials on that.
sailboart29 is offline
post #6 of 7 Old 12-03-2016
Regardless of year, model, wheel type, wheel diameter [17, 18, 19, 20 and 21 inches], and tires, when new all Touareg wheel/tire combinations are 29 inches in overall diameter, give or take a fraction.
The largest wheel/tire overall diameter that can be fitted is normally accepted to be 31.5 inches, thus you will only get another inch and a bit of ground clearance at best if fitting the largest possible wheels/tires.
color="black"> word word word
post #7 of 7 Old 12-03-2016
What he said ^
I know the speed of xx for door locking can be changed in VCDS/ So it is probably somewhere.
-Rick
My VW youtube Channel:
Xeno555 is offline
