Go Back   Club Touareg Forums > Club Touareg Technical Information > Off-Roading & Towing
Old 08-08-2008   #1
Lemontree
Lemontree's Avatar
Problem with Prodigy on '08 Treg
I thought I had it made when I found the four prong connector wrapped in foam under the dash. I located the 12v (red/yellow), ground (brown), blue to blue, and black/red...supposedly the brake switch. I have read on this site to tap directly into the brake switch wire, but there doesn't seem to be one close by. I cut the plug and wired the Prodigy to the corresponding wires (including the black/red brake switch) and I get a n. c. on the readout when hooked to the Airstream. My Chevy 2500HD works perfectly with the same model Prodigy. I'm running out of ideas. Has anyone had success hooking up a Prodigy on an '08?
2008 V8 Treg
Lemontree is offline   Reply With Quote
Old 08-14-2008   #2
ericwarren
finally got my envoy to work...turned out it was a bad controller!
the issue may be the voltage. When the brake is not pressed, there is 3-4 volts flowing. In some controllers this may be enough to mess them up. The envoy takes 10 volts to activate.
2008 Touareg 2, Alaska Gray, Anthracite Interior. Towing Package and Cayenne Rubber Mats.
ericwarren is offline   Reply With Quote
Prodigy Update Rose Lane Garage Off-Roading & Towing 2 04-03-2008 06:40 PM
Prodigy Brake Controller Problem subysti Off-Roading & Towing 15 02-27-2008 10:47 AM
AC problem (again) JohnR Problems/Bugs 8 06-20-2007 09:34 AM
Prodigy Brake Controller 04-Riverside General Touareg Discussion 0 05-12-2007 12:13 AM
Tips for installing a Tekonsha Prodigy trailer brake control OzJuJu General Touareg Discussion 3 08-02-2006 09:19 PM
