Land Rover LR4 fording - Club Touareg Forums
post #1 of 24 Old 04-01-2010 Thread Starter
Touareg: 2007 V6
Can someone please explain this...
FFWD to 1:20 and watch until 1:35 (or the end if you want).
Wouldn't this wake get sucked into the intake?
Also,
For some reason I doubt, although many of you have proven this wrong, that my Touareg can do this without sustaining some serious water/engine damage.
pazzo is offline
post #2 of 24 Old 04-01-2010
The Moderator!
Yeti's Avatar
There is a pic of my 04 floating around on this forum with water flying up over the roof of my Treg. I had no ill effects from that at all, but hindsight says it could have been catastophic. So actually the video is mild from what I put my 04 through, but is doable.
Yeti is offline
post #3 of 24 Old 04-01-2010 Thread Starter
Touareg: 2007 V6
Yea I was actually referring to your vehicle (and another member's vehicle as well). I read your whole post about it and how there was only mud to clean up.
But,
What about the constant driving through this creek? I mean, how high can the intake really be?
I'll have to stop by the local Range/Land Rover dealership and pop the hood sometime this weekend and see for myself.
pazzo is offline
post #4 of 24 Old 04-01-2010
AndrieK's Avatar
Touareg: 2004 R5 TDI
I might be wrong, but IIRC the Disco3 had a wading depth of 600mm and if you look at the aftermarket snorkel kit that was available from the LR dealers for the Disco3, it connected through the intake vent on the fender, just in front of the front doors. I suspect that this is more or less where the standard air intake sits on the Disco3 and, being not very different, probably the Disco4 as well.
In all the footage in that clip, the vent is still above the waterline.
AndrieK is offline
post #5 of 24 Old 04-02-2010
norsecarnut's Avatar
I have an lr3, the intake stuff is identical. The advertised wading depth is several inches higher than Touaregs with air suspension and yes, the air intake is the vent at the top of the fender. Not only is it about the air intake but almost as important, other breather tubes for axles, and such. Rovers in general for many years have had high wading depths by bringing the breather tubes up higher. I have seen photos of nutty rover drivers with water consistently at the window! but it can't be good for a lot of other little parts.
Current:
2008 Audi S4 Avant mt6
2008 BMW 535xi Touring 6 spd
2007 Land Rover Discovery 3 modified
2004 Land Rover Discovery 2
1996 Land Rover Discovery 1 / 230,000 miles
norsecarnut is offline
post #6 of 24 Old 04-02-2010
Mojo0341's Avatar
http://<object width="640" height="3...mbed></object>
Okay After seeing this Video I was a little impressed but what's the COST and history....The egg is capable but really when IN THE WORLD WOULD YOU NAVIGATE THAT TYPE OF ANGLE>>REALLY!
To comment on the first video post on this thread..My response.."Okay and what did your vehicle do that was so special"! LMAO! YOU ARE NOT ALONE!
I hope I added the video link correctly!
2004 Touareg V8 Vin:57***,4corner air susp, 4 zone climate control, Navi, Solar shades, LED cig Flash light, Exterior:Venetian Green Metallic, Interior:Anthracite, Xenon lights...
SEMPER FIDELIS
Mojo0341 is offline
post #7 of 24 Old 04-02-2010
Mojo0341's Avatar
OkayI'll try this again!
SEMPER FIDELIS
Mojo0341 is offline
post #8 of 24 Old 04-02-2010
Mojo0341's Avatar
Here we go!
SEMPER FIDELIS
Mojo0341 is offline
post #9 of 24 Old 04-02-2010
that's an exaggerated video. camera angles and wide angle lenses distort things. just like when you take a shot that can't capture an angle, well here it is exaggerated due to the same lens issues. yes, it's steep, but it's all obvious in the wheel lift, that's the only real truth and yes, it's steep, but not as much as it's made to look.
that hill is also a wee bit stupid to go up because the slightest screw up and you roll the vehicle.
Current:
post #10 of 24 Old 04-02-2010
hahaha. so i just watched the water video - i was expecting it to be deep, for real, but it wasn't even that deep. the touareg, with air suspension would do the same crossings just fine, no issue at all. someone made it sound like it was cresting the hood but it was barely over the tires. funny stuff.
Current:
Realistic Fording Ability FLOffroad Off-Roading & Towing 43 09-08-2009 11:19 PM
My 2000 toyota Land cruiser Linder Auto Anything (Non-Touareg Topics) 0 01-28-2008 09:31 PM
Land in Colorado Foghorn Off-Topic Forum 10 07-07-2006 03:29 PM
6 wheelers Range Rover and Land Rover... have you seen them? 12johnny Auto Anything (Non-Touareg Topics) 5 09-22-2004 11:30 PM
impressed the local Land Rover dealer originalplaid General Maintenance & Repair 0 04-11-2004 05:55 PM
