Go Back   Club Touareg Forums > Club Touareg Technical Information > Touareg Mods
Old 07-05-2008   #11
lzvagias
Originally Posted by matthew@f View Post
they draw up 30 amps!!!! on the alternator... that's a lot of energy/HP!!
A stereo system can use way more and cars electrical system handles it without any notable decrease in HP. I've had small amplifiers that were fused for 50 amps.
BTW- I stand corrected, the Honda I mentioned turns out to be a fuel cell car.
lzvagias is offline   Reply With Quote
Old 07-05-2008   #12
matthew@f
you are not mechanically minded i am guessing
07 Pajero 3.2 DiD
R5 Egg (scrambled and retired)
Beetle 2.0 IKON
Toymotor Hilux 1 Tonne
Honda MDX (hairdressers 4wd!!) retired
had a centre diff issue just like an Egg!!!
08 Lexus RX350 sports lux (another hairdressers 4wd)
matthew@f is offline   Reply With Quote
Old 07-09-2008   #13
lzvagias
Uh... actually, in my free time I build custom choppers from the ground up but thanks for asking.
I do know that an alternator adds additional load to the motor and I understand that stock alternators have a limited amount of amperage that they are capable of producing. I also know that stock alternators are perfectly capable of handling a 30amp device. What I don't understand, specificly, is how adding an additional 30amp device is going to rob more horsepower. But I'm always willing to learn something new.
Old 07-10-2008   #14
matthew@f
well you don't pluck 30amps out of thin air! it has to be made with air and fuel ...
nice chopper!!!
07 Pajero 3.2 DiD
Beetle 2.0 IKON
Old 07-10-2008   #15
spockcat
spockcat's Avatar
Images: 15
Perhaps I'm wrong but as you increase the electrical demand on an alternator, doesn't it become more difficult to turn the alternator? Thus, you are using more of the engine's horsepower?
spockcat is offline   Reply With Quote
Old 07-10-2008   #16
Vegas Matt
Vegas Matt's Avatar
This is how I've always understood it as well. More load on the alternator, the harder it is to spin. The harder it is to spin, the harder the engine has to work to spin it, therefore the loss of engine efficiency.
The question becomes: Does this hydrogen dealie make up enough for the loss of baseline engine efficiency to make it worthwhile? Breaking even is not making it worthwhile.
Matt
Old 07-10-2008   #17
matthew@f
last time i looked our local power station uses a bucket load of coal to turn the generator..
07 Pajero 3.2 DiD
Beetle 2.0 IKON
Old 07-10-2008   #18
lzvagias
Perhaps this is where my confusion is rooted, the way I have always thought that the alternator works is that it creates a certain amount of power which is governed by a voltage regulator. In other words, once the motor reaches a certain RPM (ie the correct idle speed) it is creating as much electricity as it would at 6500 RPM. I may very well be wrong about that but this would make more sense than if the voltage/ amperage fluxuated with RPMs. I would think that your lighting system, computer, stereo system, and ignition would all be very sensitive to fluxuations in current. Again, I could be completely wrong about this as I am certainly no expert in D/C electrical systems.
Old 07-10-2008   #19
nickm
nickm's Avatar
As far as I understood it, amperage is never drawn directly from the alternator...its always drawn from the battery. I understood the electrical system to work as described by lzvagias, where a consistent charge is being created by the alternator and fed to the battery in a linear - non rpm dependant fashion. I don't think there is any load difference on the alternator (ie: it turns at the same rate regardless of current draw on battery)....this is why you see capacitors on high end audio systems, they are there to store energy for the peak current draws...
Old 07-10-2008   #20
lzvagias
Yep, you are 100% correct! But our cars use fossil fuels instead to run our motors which, guess what..... run our, well I think you see where I'm going with this.
Park Assist ahujapradeep General Touareg Discussion 11 06-18-2008 03:34 PM
parking assist Earlie General Touareg Discussion 0 06-23-2005 02:34 PM
Parking Assist sleepera8 General Touareg Discussion 5 06-23-2005 12:34 AM
Extra fuel tank? External fuel tank? smshnick Touareg Mods 5 10-01-2004 12:18 PM
Parking assist Devoman General Touareg Discussion 4 02-29-2004 07:48 AM
