DIY headlight restoration - Club Touareg Forums
post #1 of 8 Old 10-09-2016 Thread Starter
nikoloz's Avatar
Arrow DIY headlight restoration
hi all touareg lovers.
i got my 05 V8 for 4 years now and my headlights have been going more and more hazy and yellow but i did not want to do it in the way as most of the guys do, polishing and buffing it out it just waste of time as they will become yellow again very soon.
probably most of you know that there is factory protecting film coating on the headlights but eventually it fails, especially if the car is parked outside in the sun. the biggest problem is the suns UV rays and oxygen,
here is the step by step guide how i restored my headlights, and i think its the best and most long term protection.
step 1 : remove headlights
step 2 : prepare sandpapers 400, 600, 1000. 1500. 2000. and 2500 grit
step 3 : you will need a hose or a bucket of water
step 4 : start sanding with 400 grit sandpaper, always keep the surface wet. this is the most important step as you will need to remove all the old yellow film and stone chips and every scratch that needs to be removed. remember that 400 grit removes everything tat needs to be removed and other grit sandpapers are only used to make surface more and more smooth so it will be possible to spray the clear coat on them.
step 5 : as you increase the grit, you have to remember that if you have not removed all the unwanted stuff from your headlights with 400 grit 600 grit will not do the job. only reason you will use 600, 1000, 1500, 2000 and 2500 is that you will need to make it as smooth as possible. as i said earlier you need to keep surface wet all the time, dont forget to do all the surfaces evenly with all grits you use.
step 6 : when done with sanding rinse it with water and wash off all the remaining dust from the surface of the headlights and let it dry throughout for at list 4-5 hours.
step 7 : before spaying clear coat use rubbing alcohol to remove any unwanted contamination from the headlight surface.
step 8 : choose the clear coat that will protect from UV rays and it will be as transparent as possible, you can also add some color to it if you want to. like little bit of black or blue or violet to have more effective looks,
i asked my friend to spray the clear cot for my as he is a professional and he knows how to do it in the best way, we used ceramic clear coat and little bit of violet paint to make it look fresh. color is hardly noticeable.
after spraying 2-3 layers of clear coat you may have a little bit of ''orange peel'' and you have to use 3000 grit Trizak and than buff it out with a polishing machine
in my case i did not need it as my friend dose have some magic hands he is one of the best car painters here in Tbilisi. Georgia.
if you will have any questions ill be happy to help
ID:	160746   Click image for larger version
ID:	160762   Click image for larger version
ID:	160778   Click image for larger version
ID:	160794   Click image for larger version
ID:	160810   Click image for larger version
ID:	160826   Click image for larger version
ID:	160842   Click image for larger version
nikoloz is offline
The Following User Says Thank You to nikoloz For This Useful Post:
koren (10-12-2016)
post #2 of 8 Old 10-12-2016
Amazing job!!!!!!! I'm doing the same and can't really achieve the same results. I got the same looking light after I sanded it with 2000 grit (by the way I'm using the same sandpaper), however everything becoming hazed after applying clear coat...
I will post the pictures tomorrow, may be you can help me figure out what I'm doing wrong!
koren is offline
post #3 of 8 Old 10-13-2016 Thread Starter
nikoloz's Avatar
about sanding i can recommend not to do circular motion, do only horizontal or vertical motion, and for the final sanding finish with horizontal motion as it will help the clear coat to level itself evenly,
when you will wash them after sanding and it will be wet you have to have almost perfectly clear headlights, as if they are already done, as they get dry its lightly hazy,
as soon as you will clear coat them they have to be as clear as with water, even better, but if they are becoming hazed its something to do with the clear coat, its reacting to plastic probably.
nikoloz is offline
post #4 of 8 Old 10-13-2016
this is how it looks like after applying clear coat
And it looked exactly like yours after 2500 grit
Will try to sand the clear coat with 3000 grit and see if it will help. If not, I'll just buy different clear coat.
koren is offline
post #5 of 8 Old 10-14-2016
I was amazed with mine also, until 1 year later, and it returned to looking 10 years old.
-Rick
My VW youtube Channel:
Xeno555 is offline
post #6 of 8 Old 10-14-2016 Thread Starter
nikoloz's Avatar
i think its the problem with the clear coat, use a different type
nikoloz is offline
post #7 of 8 Old 10-30-2016
Olblueiiii's Avatar
Headlight Restoration
Wow, Nikoloz, those came out GREAT! I hadn't heard of adding a little color to the clear, but it makes sense.
I restored the headlights on my 2005 V8 just last month. I used the Meguiar's kit and they came out almost as well as yours did. The kit has you wet sand from 1000 grit to 3000 grit, but that bothered me, so I wet sanded with 600, 800, 1000, 1500, 2000, 2500, and then the 3000 grit. After that, you use a cloth mop on the end of a drill with a dollop of special polish. Then you finish with a wipe-on UV protectant. I'm very happy with how they turned out.
@ Koren: I agree with Nikoloz. There must be a problem with the clear coat you're using. They make that stuff in satin and flat as well as gloss. I've made that mistake before, as it's not always prominently displayed on the can.
@ Xeno555: Time will tell if I'll have the same experience as yours. But, if mine start to look bad again, I'll just repeat the process. It wasn't that hard to do.
2005 V8, Reed Green w/ Anthracite, Air Suspension, 4 Zone Climatronic, Keyless Entry, Xenons w/ 6 Light Salute, Self-Installed Factory Tow Hitch
Olblueiiii is offline
post #8 of 8 Old 1 Week Ago
I have had good luck with just polishing mine on a fairly regular basis, but for really faded/pitted lights, this DIY is amazing....
Tifoso is offline
