Hi all. While driving home tonight in our late 2004 V10 I got the dreaded consumer electronics message. I had the wheel turned as I was in a right turn coasting but merging onto another road. The turned wheel kept me from reading the whole message for maybe 1 sec and by the time the wheel was straightened out the message was gone.
We are at 64K miles on the original battery. I have kept an eye on the voltmeter and it has always been a steady 14+ even with all heated seats, lights, radio, high beams and the whole works on. After the message blinked on ever so briefly I was accellerating and the reading was a strong 14.
No issues the rest of the way home until I got to the mailbox and was back to an idle. Now the gauge was reading 13 or so. I accellerated up the driveway and idled into the garage and the meter was reading between 12 and 12.5. I've checked codes using the VAG-COM and see nothing unusual.
The batteries are almost exactly 4 years old now. We have not had the alternator cable TSB performed because we have had no problems to date (Also I'm not sure our V10 VIN meets the TSB requirements for either one anyways).
So several questions:
1. Bad battery or generator (the V10 apparently has a generator not an alternator)?
2. Four years on a battery seems sort of low, but what have others been getting?
3. For those that have replaced their V10 batteries (under drivers seat and in back with spare?) what have you used and where did you get it? VW? Aftermarket? Recommendations?
4. Did you replace both batteries or just one and if so, which one?
From what I can tell If I take it to my dealer (and I have a good relationship with our dealer) their first move might be to suggest it needs a new battery because of it's age. I am perfectly capable of doing the replacements so I'm thinking I might do a battery swap and see what effect that has before taking it to them.
Any suggestions or experiences other V10 owners can share?
Thanks much,
Nancy
Thanks much,
Nancy
