Old 08-19-2008   #1
MGLXYY
Turning off the Pressure Monitoring System
Hi, I changed the wheels of my 04 trg from 19 to 17inches to get a better tires. But I couldn't put the pressure monitoring device to the smaller wheels since they are customized to fit the wheel sizes. Ever since, it says FLAT TYRE on the monitor and I couldn't do anything about it. Heck, I don't think I need the PMS so I want to turn it off. Any advise how to do that. Tnx
MGLXYY is offline   Reply With Quote
Old 08-19-2008   #2
Yeti
Yeti's Avatar
Images: 4
I took mine out completely and it is not hard but you do need a VAG Com cable and software to do it. Here is the link to the procedure I used to remove mine: http://www.clubtouareg.com/forums/f4...diy-17986.html
Old 08-19-2008   #3
MGLXYY
Could you explain it a little more, how do I get that software and cable, could I just go to VW dealer and would they have that software?
Old 08-19-2008   #4
Yeti
Yeti's Avatar
Images: 4
The dealer will not touch it and the cable is available here: www.ross-tech.com . Get the cable and software then read the procedure I posted the link for. It will no longer be there and no more errors at all.
Old 08-19-2008   #5
MGLXYY
Tnx, Yeti. I see that you are in SLC, i used to live there myself, anyways, Could you tell me how to turn off the DRL? (day running lights)
Old 08-19-2008   #6
EARL97850
EARL97850's Avatar
Same thing bud...have to have a VAG-COM.
Cya
'05 VW Touareg V6 Campanella White/Anthracite
'02 VW Jetta GLS TDI Galatic Blue/Beige
EARL97850 is offline   Reply With Quote
Old 08-19-2008   #7
Yeti
Yeti's Avatar
Images: 4
Get the cable and software, then you can mess with that stuff. There is no other way really. I am not from SLC, I moved here 7 years ago for the skiing.
Old 08-20-2008   #8
MGLXYY
Well, tnx again everybody
Old 08-20-2008   #9
Yeti
Yeti's Avatar
Images: 4
Originally Posted by yendis View Post
Never mind, it was spam
WTF are you talking about and WTH does that link have to do with what the thread is about?
Last edited by Vegas Matt; 08-20-2008 at 11:45 PM. Reason: Removed quoted spam comment
Old 08-28-2008   #10
subysti
On my MFI I have the option to turn off the TPMS right there. Go in to the the tyre settings and the last option is an on/off setting.
2004, Red V10 TDI, loaded!!!
subysti is offline   Reply With Quote
tire pressure monitoring system fault runnerfast Problems/Bugs 11 09-24-2008 10:55 PM
Check out my Tire Pressure Monitoring System supertouareg General Touareg Discussion 1 07-22-2008 07:40 AM
Flat Tire and Air Pressure Monitoring System Greek Problems/Bugs 2 06-26-2007 10:16 AM
Tire Pressure Monitoring System Failure enaye Problems/Bugs 3 01-29-2007 09:54 AM
VW RECALL tire pressure monitoring system TOUAREG-HOLLAND Problems/Bugs 3 03-05-2004 10:13 AM
