Old 08-14-2008   #1
maxianella
Question Headlight out, not the bulb
2004 Cert. reg Xenon: I have a driver side hi/lo headlight out. I thought it was the bulb, but swapped it out to the other side and it works there. I thought it could be the fuse, but they all test fine. Does anyone have any experience with wiring issues?
maxianella is offline   Reply With Quote
Old 08-14-2008   #2
Vegas Matt
Vegas Matt's Avatar
Possibly the ballast, which is listed as the igniter in VW-speak. It is the other half of the xenon headlight equation.
Matt
Old 08-14-2008   #3
maxianella
Is this part of the bulb housing or somewhere else? Thanks, I will look into this.
Old 08-14-2008   #4
Vegas Matt
Vegas Matt's Avatar
It is a separate unit. The igniter is built into the D1S bulb, but the ballast (which VW actually calls the igniter) is a separate unit. I believe it is beneath the headlight assembly, but am not sure.
If you check out the parts breakdown of the headlight assembly on 1stvwparts.com you can find a diagram showing it.
Matt
Old 08-14-2008   #5
maxianella
Thanks for all of your help.
Old 08-14-2008   #6
Depiry
Matt,Bulb,ballast,igniter are one assembly in the D1S lamp,thats why it's costly double check fuses,and bucket connection,Marty,
Depiry is offline   Reply With Quote
Old 08-14-2008   #7
maxianella
I have an appt with the VW dealership. I am told if it's not the bulb, which I have proven it is not then it is covered under the certified warranty. Thanks for everything.
Old 08-15-2008   #8
mrlvdub
I'm going to piggyback on this.
Last week passenger bulb started flickering and finally went completely out 2 days ago. I suspect that it is the headlamp assembly (not sure yet as I have not swapped bulbs to confirm). I have a 2005 with 77,000 miles that was purchased in Oct 04 (way prior to CW 31/05). Did not see any restrictions or limitations in the TSB. If the assembly is the problem, will I still be covered under the TSB for this issue?
Driver side assembly was replaced under warranty for the same flickering in early 2007.
Thanks,
Mike
05 VW Touareg V6 Blue Silver - Eq. Pkg. #2, Navi, Bi-Xenon, Park Asst
01 VW Passat GLX - OEM Navi, OEM HIDs, OEM Clear Corners and sidemarkers, Euroswitch, W8 Sunroof Panel, Sharan Antenna, Alientech, Vestatec front fogs, Rear Foglight, Warning Triangle
mrlvdub is offline   Reply With Quote
Old 08-16-2008   #9
ricci5
i have an 2004 with hid's and my lights have been changing colors from blue to white, and back. Currently one is blue and the other is white. I am getting tired of my treg, too many problems, and too slow and too much gas. I have an 04 with all neuspeed options intake,cat bypass, chip, exhaust,etc.
ricci5 is offline   Reply With Quote
Need a xenon headlight bulb for my 04 touareg Jreg Classifieds 1 11-30-2007 12:40 PM
HELP PASS-SIDE HEADLIGHT TO CHANGE BULB TOUAREG V6 NON XENON no03330 General Touareg Discussion 1 07-17-2007 11:10 AM
ACCESSING THE PASSENGER SIDE HEADLIGHT (BULB REPLACEMENT) no03330 General Touareg Discussion 0 07-13-2007 07:28 PM
$144 to change a light bulb!? and no, its not a HID bulb TStalcup General Touareg Discussion 3 05-04-2007 11:04 AM
Thanks Spockcat! Headlight bulb swap QuincyVW Touareg Mods 0 06-18-2005 08:00 PM
