#21 |
No,lights never come on.I swear I can smell anti-freeze though,but the tank is always full.
08 Touareg Uniblack,Lux pckg.,06 Reflex Silver Passat vr6 |
#22 |
I had the same problem with the 04'. Did it for a couple of days and then stopped. I started a thread on this about a month ago. I was disconnecting the fans when I got home so that it wouldn't drain the battery. But after that I have never had any other issues and or errors. One of those "fix itself" things again.
Gotta live for the moment...tomorrow is not promised |
#23 |
try replacing the sensor right below the backside of the intake manifold on the fire wall side. its a grey 4 pin sensor...
dont forget to check & clear faults in the ECM & climate control !!!! the fans will still run if it still has a fault in the system.
fix it till its broke. Last edited by vwdoctor; 4 Weeks Ago at 10:52 PM. Reason: needed to add fault data |
#24 |
Can you explain why it doesn't occur all the time. This has happened to me 4 times. I never get any alarms, the fans stay on and I end up disconnecting them so that they don't drain the battery. At one point it was doing it for a week, and then just stopped like all the other times.
#25 |
My 04 V8 did this and it ended up having a faulty waterpump and Thermostat
$1800 later.... Basically ended up doing my 80k timingbelt maintenance 10 k earlier
own 2004 V8 touareg, nav, air suspension |
#26 |
Strange,the weather is cooler know so it doesn't run at all,when you shutdown,maybe oil temp is lower.
| Thread Tools | |
| Display Modes | |
| COOLING FAN STAYS ON UNTIL THE CAR IS OFF!!! HELP PLEASE!!!! | Carlfb | Problems/Bugs | 4 | 01-21-2005 10:04 AM |
Other
Social Knowledge
