Vibration - highway Speeds - carrier Bearing - Page 2 - Club Touareg Forums
post #11 of 16 Old 02-02-2012
JKUCSMA's Avatar
Touareg: 2008 V6
I had some Goodyears that did the same thing,they found bad belts in the tire.The tire would be in balance on the machine,then when you drove it the belts shifted and it was out of balance,no cure except new tires.I'am not saying yours is the same problem,but a tip.
08 TouaregV6 Uniblack,Lux pckg,Nokian WRG2 SUV,255/65/17.,09 CC 4Motion,Black on Black
JKUCSMA is offline
post #12 of 16 Old 02-03-2012
Try to note the rpm range and what gear you're in when this happens. My '05 V8 has a distinct vibration at very light throttle between 1800 and 2500 rpm in 6th gear. I've tried 6 sets of tires and driven 3 similarly equipped vehicles and was able to replicate it every time. VW even acknowledged it and it's been diagnosed as "operating as designed".
pilottim is offline
post #13 of 16 Old 04-12-2012 Thread Starter
ryangambrill's Avatar
Carrier bearing went. Must have been the problem. I dont put a ton of miles on the vehicle. That is why it must have taken a while to go.
Estimate from VW dealership is $1800. Lucky I have VW Real Driver. With this repair, I have officially made money on my VW Real Driver contract.
2 Repairs for a total of $4000.
2004 - Porsche 911 - 40th Anniversary #693
2008 - VW Jetta - Wolfsburg
2006 - VW Touareg V10 TDI
Previous Cars:
99 - CLK 430 Coupe
01 - GS 430
01 - VW Jetta - GLS
04 - A4 1.8T Quattro
05 - VW Touareg V8
ryangambrill is offline
post #14 of 16 Old 04-12-2012
Touareg: 2013 V6 FSI
Originally Posted by fincher View Post
When I have had the issue it is only at highway speeds. Definitely have the tires re-balanced...a slight difference will only show up at highway speeds.
This has happened to me right after a tire rotation.
Mine is 70-80mph. Also intermittent occurences. I'm assuming it has to do w/ air pressure amongst the four tires as well as a balance issue.
We've been going from high 80's to low 30's temps....so they've been fluctuating a good bit.
It's a slight vibration in the steering wheel...and if held somewhat firmly, goes away. Other times, I can let go and there is no vibration at any speed.
This is full auto, so 6th gear at those speeds/vibrations.
I have no "noise" at all with this vibration...
Str3t is offline
post #15 of 16 Old 04-12-2012
Moderator
hedditch's Avatar
Originally Posted by ryangambrill View Post
Light vibration but still noticeable. Took to my dealer. They recognized the vibration but said they were unable to pinpoint the cause.
Is there a way to better diagnose the cause?
Dealer recommended giving it more time and returning when it gets worse.
Advice?
It looks like your symptoms were confirmed..
This is exactly what I identified to my Dealer, and they diagnosed it as the first signs of a tail shaft carrier bearing failure. It was replaced under extended warranty. My car had done 106,000 km at the time ( 66,000 miles). Started as a light shudder at highway speed.
Would be worthwhile for other to think of carrier bearing rather than being side tracked by "wheel balance".
Stuart.....
2008 V6 TDI, Air Suspension, ACC with Front Assist, Paddle Shifter, RNS510, Leather Seats, BI Xenons, 4 Zone Climatronic, Sunroof, Towbar & Trailer Module,Fiscon Bluetooth. Reversing Camera, Front Fog Lamps Xenon 3000K, Redarc TowPro Brake Controller, T1 Door Warning Lamps, T1 Under Seat Drawer, Alloy Skid Plate, 5ton Winch, Cayenne (Green Dot) Front and Rear Sway Bars, Performance Tune by Oettinger, Retrofitted 6 Piston Brembo Front Brake Callipers, Custom Sports Steering Wheel
hedditch is offline
post #16 of 16 Old 04-17-2012
Touareg: 2005 V10 TDI
I recently bought a V10tdi with an intermittent vibration problem. Have read all the threads on carrier bearings, tyres and roof rack but it turned out to be a faulty injector and speed sensor.
Just got it back and it's running perfectly....if it's this the diagnostic check should find it.
Timreid is offline
DRIVESHAFT Carrier Bearing Lifespan? BonesNTX Engine, Transmission and Exhaust 206 10-21-2016 09:00 AM
Center Propshaft Carrier Bearing manda3000gt General Maintenance & Repair 104 08-03-2014 10:49 PM
Center carrier bearing fledermaus98 General Maintenance & Repair 4 04-30-2011 04:00 PM
Annoying noise at highway speeds when taking your foot off of the gas 04offroadgrey General Maintenance & Repair 1 05-11-2010 05:47 PM
Massive Vibration at speeds over 80MPH. dlwaddle General Maintenance & Repair 11 01-29-2010 06:56 AM
