Old 05-23-2008   #1
Jonny
Jonny's Avatar
Images: 3
VW iPod Car kit & Bluetooth USB/MP3
I have done some research on trying to find something to hook up all of these items, Has anyone seen this stuff ?? I am ordering up one to try out , I am able to order at a discounted rate if more then one ! When I receive this I will post photos and feedback .
#1 Will I be able to see the song tracks on the screen
[FONT='Arial','sans-serif']It is not possible for it to display track names/information on the head unit in this way. However you can still view track timer and the ability to control your ipod through the car stereo/steering wheel controls. Access to your iPod controls will also be fully available when connected, allowing you to control the ipod itself using the clickwheel etc. [/font]
#2 Will it charge the ipod at the same time
Yes the ipod will be charged automatically when connected.
#3 Will the controls work on the steering wheel ?
Yes, you can control the ipod through the steering wheel controls, just as if you were using a CD changer
Please also note that our interface allows you to retain your CD changer, and will not lock the ipod screen/controls when connected.
The VW iPod Car kit allows you to connect your IPOD to your VW factory car stereo system without any loss of sound quality!!
Simply perfect CD quality sound all the time. It will also allow you to control your iPod through your factory radio and steering wheel controls.
Features
  • Connect your iPod to your factory fitted car stereo and enjoy perfect digital CD Quality Sound!! Direct Connection to the CD changer port, This is not an FM transmitter, no FM modulation involved.
  • Control your iPod through your car Stereo and steering wheel controls. Select tracks, rewind, fast forward and adjust the volume through your existing volume control.
  • CONTINUE TO USE YOUR EXISTING CD CHANGER
  • Select Playlists through your car Stereo and steering wheel controls
  • When the iPod is connected, you will have full control on ipod from the iPod itself, your iPod and screen will NOT be disabled when connected
  • Automatic Pausing when switching to CD/TAPE/FM/AM/MD etc
  • No batteries required, keeps your iPod fully charged all the time while connected
  • Designed for the professional look, no cigarette lighter adapters, all wires hidden
  • Power on automatic play function and power off automatic pause.
  • 3.5mm connection for connecting MP3/MP4 Player and iPod shuffle
This connects directly to the existing CD changer port on your car stereo Which in some cars can be reached from the passenger side, on other cars the car stereo will need to be removed. Instructions to remove your car stereo to access the CD changer port can be found through many online resources, car manuals or by a local installer. On most cars the unit can be installed in approx 30 minutes. One of the unique features of the VW interface is that it has an input connector which enables you to continue using your existing CD changer.
COMPATIBILITY:
Compatible with Delta 6, RCD 200, RCD 300, RCD 500 and MFD2 Satnav Units. Factory radios, normally fitted to Passat, Tourareg from 2003 onwards and Mark V Golf.
Compatible with All Ipod's with dock connector including: Ipod Video 30GB, 60GB and 80GB Ipod Nano, ipod (3,4,5 Generation), Ipod Photo, Ipod Mini, Ipod U2.
Now also compatible with the latest iPod Range including iPod Nano 3rd
generation, iPod Touch, iPod Classic and the Apple iPhone.
USB/MP3 INTERFACE WITH BLUETOOTH A2DP SUPPORT!!
FULL IN CAR COMMUNICATION AND ENTERTAINMENT INTERFACE
The VW USB/MP3 interface is perfect for connecting a USB Disk or MP3/MP4 player to your factory stereo. This Bluetooth units retain all of the same functionality adds the convenience of Bluetooth connectivity. When connected to a bluetooth device you can enjoy music thorogh a USB drive/SD Card or MP3/4 etc and then when an incoming call is received the music playing will automatically pause and the call can be heard through the car stereo speakers. Music playing then resumes as soon as the call ends. For added convenience there is a call answering button located on the microphone.
In addition it can also be used to wirelessly stream music from a A2DP bluetooth enabled mobile phone!
This is the perfect option if you do not have an iPod. The USB /MP3/Bluetooth Car kit allows to connect your MP3/MP4 player to your VW factory car stereo system without any loss of sound quality!! Simply perfect CD quality sound all the time.
It will also allow you to control your MP3/MP4 through your factory radio and steering wheel contols.
Features:
  • Connect your MP3 player or USB disk to your factory fitted Car Stero Enjoy Perfect Digital CD Quality Sound!! Direct Connection to the CD changer port, No FM Transmitters.
  • One of the other key benefits is the ability to control your MP3 player / USB disk through the controls of your factory car stereo/steering wheel. You can even setup folders as Albums or Playlists and select them through your car stereo and steering wheel controls. Click here for more information.
  • Continue to use all MP3 player or USB Disk functions when connected.
  • Continue to use your existing CD Changer
  • Designed for the professional look, no ciggarette lighter adapters, all wires hidden Power on automatic play function and power off automatic pause. Built in SD Card slot WMA File Support Aluminium Body
  • Bluetooth A2DP Support Built in Microphone
  • Automatic Pause when receiving a call and resume when call ended.
  • Wireless music streaming
This connects directly to the existing CD Changer port on your Car stereo (as shown in the diagram below) Which in some cars can be reached from the passenger side, on other cars the car stereo will need to be removed. Instructions to remove your car stereo to access the CD changer port can be found through many online resources, car manuals or by a local installer. On most cars the unit can be installed in approx 30 minutes. One of the unique features of the VW interface is that it has an input connector which enables you to continue using your existing CD changer.
Compatibility:
Compatible with Delta 6, RCD 200, RCD 300, and RCD 500 Factory radios, normally fitted to Passat, Tourareg from 2003 onwards and Mark V Golf.
Compatible with all MP3/MP4 players including Creative Zen, Sony Walkman etc and USB Flash drives.
Please email us with the model of your car stereo if you have any queries regarding compatibility
2008 VW Touareg VR6 Alaska Grey , 19inch Wheels, Lux Plus Package,Technologie Package, Loaded Everything!! : ) A Picture Is Worth A Thousand Words !
jonnycurrier.smugmug.com
Jonny is offline   Reply With Quote
Old 05-23-2008   #2
spockcat
spockcat's Avatar
Images: 15
1) Won't show the music track into on the head unit.
2) Will charge iPod but so will all other iPod adapters, including $69 Blitzsafe unit.
USA Paypal order form
spockcat is offline   Reply With Quote
Old 05-23-2008   #3
Jonny
Jonny's Avatar
Images: 3
None of them that I have found will show the music tracks I WISH !!!
Any adapter will charge them I just thought this one was unique with steering wheel controls . Plus simple plugs easy instructions and install.
Same price as Blitzsafe Unit but more option .
Old 09-06-2008   #4
Fantaxp7
Is the ipod adapter you mention in the first post the factory one made by VW? If it is, can u give me a link of where you bought it? Also, will that bluetooth adapter work with the ipod adapter? Thanks
Fantaxp7 is offline   Reply With Quote
Old 09-07-2008   #5
RJB7266
RJB7266's Avatar
will it charge the iphone 3g?
* 2004 Black V8 Touareg | Teak Interior | Air Suspension | Rear Differential Lock | Michelin 4x4 Diamaris Tires
RJB7266 is offline   Reply With Quote
Bluetooth problems Trien Mobile Electronics 3 05-19-2008 10:07 AM
Installing Ipod, XM & Bluetooth - best way? BigEasyTreg Mobile Electronics 2 03-02-2008 07:20 PM
Motorola Bluetooth FSures Mobile Electronics 7 02-28-2008 06:18 PM
Best option for iPod, XM Radio & bluetooth phone? BigEasyTreg Mobile Electronics 1 11-05-2006 04:41 PM
Adding Bluetooth Phone, Ipod Controller, dvd player and XM Harlet225 Mobile Electronics 2 09-17-2006 07:03 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
