Old 05-05-2008   #11
ewaynek
I need those instructions
Just installed this unit in my 2006 Passat and I am having the same issue - no DVD display even when the parking brake is set. If you would, please post the details for the switch.
ewaynek is offline   Reply With Quote
Old 05-05-2008   #12
C Rev
Im having the same issue with steering wheel controls with the Apline IVA-W505. I bought the SWI-Jack and the SWI-CAN, supposed to be compatible with the headunit not sure about pioneer though. Problem is can tfingure out how to hook it up.
C Rev is offline   Reply With Quote
Old 05-05-2008   #13
TXTreg20
TXTreg20's Avatar
Images: 9
Hey ewaynek. For the DVD bypass I used a Momentary Pushbutton Switch, Normally Closed, rated 0.5A at 125VAC, 0.3A at 50VDC. The part number is 275-1548 at Radio Shack. That was for a pack of four.
Run that green wire(thats supposed to go to the e-brake) to one side, and then run a wire from the other side to a grounded connection... I actually ran this wire to a bolt on the e-brake! Turn it on, push the button, and it should work. Let me know if you have problems.
_______________________________________
Morgan
Dallas, TX
2004 V8 Silver
TXTreg20 is offline   Reply With Quote
Old 05-05-2008   #14
TXTreg20
TXTreg20's Avatar
Images: 9
C Rev, not sure about the steering wheel controls... I was told there was nothing compatible between VW and Pioneer.
Morgan
Dallas, TX
2004 V8 Silver
Old 05-05-2008   #15
ewaynek
Wow, it is very strange that all it takes is a momentary switch that grounds the circuit. I have the PAC C2R-VW adapter installed which is supposed to take care of the parking brake sensing circuit. The only time it works is when the green wire is connected to the parking brake wire AND as long as the parking brake light is illuminated. When the brake light goes out after about 15 seconds the DVD picture is replaced with the warning screen.
Old 05-06-2008   #16
marvdoc30
Hello I just purchased the Pioneer AVH-P4000DVD as well. If possible can you tell me what I need to buy and how to do it so I can play movies in motion. I don't know how to do the bypass. I really would appreciate it if someone can help me. Thanks..
"Doc".....
marvdoc30 is offline   Reply With Quote
Old 05-06-2008   #17
TXTreg20
TXTreg20's Avatar
Images: 9
marvdoc30: Get everything installed, and leave that green E-Brake wire hanging out somewhere you can access it...
Then go to Radio Shack...
For the DVD bypass I used a Momentary Pushbutton Switch, Normally Closed, rated 0.5A at 125VAC, 0.3A at 50VDC. The part number is 275-1548 at Radio Shack. It's like 3$... That was for a pack of four.
Morgan
Dallas, TX
2004 V8 Silver
Old 05-06-2008   #18
TXTreg20
TXTreg20's Avatar
Images: 9
C Rev, dude... nice dash rtrim around the head unit - might I ask where you got that?!?
-M
Morgan
Dallas, TX
2004 V8 Silver
Old 05-07-2008   #19
C Rev
-M
Thanks man. Yeah it some cheep vinayl wrap i picked up off ebay for like $8.00 shipped. I just wanted to get a feel for what it would look like. Im about to send the dash kit off to get profesionaly done with better material.
As far as steering wheel controls has anyone tried this:
Products
I have this but I cant seem to figure out how to hook the thing up.
Old 05-07-2008   #20
ewaynek
TXTreg20, it did not work for me. After checking the installation manual again it looks like the other side of the switch needs to be connected to power - "This lead needs to be connected to the power supply side of the parking brake switch."
How to install the fabspeed Bypass Pipe on the 4.2L V8? T-Reg-Gray Touareg Mods 0 01-20-2008 04:05 PM
Pioneer AVIC-Z1 install rv99 Mobile Electronics 7 01-09-2007 12:30 PM
Getting ready to install the Pioneer Nav system msocal Mobile Electronics 1 10-31-2004 06:57 AM
Hitch Install Instructions tregcentral.com General Touareg Discussion 1 05-17-2004 09:31 AM
