09-21-2006
#3 |
| Senior Member
Touareg: 2004 V8 Join Date: Nov 2004 Location: Philadelphia Main Line
Try recalibrating the unit. I don't know if the procedure survived the server crash but I made a text file copy of it some while ago: Quote:
Navigation always off!! Leads on wrong turns and directions
Author Message
TheWizard
Pictures: 0
Posted: Fri Jul 30, 2004 9:59 am Post subject: Navigation always off!! Leads on wrong turns and directions
Hey guys a little help would be great.
I have had my Treg for over 3 months now and I know that most already know that the NAV is a POS!! I figuired i would give it a chance and have been using it fairly frequently for the past 2 months. I am now even more convinced that this thing should have never been installed in this car and the cost of this *&^&&&^% is way too much for what it does and doesnt do. I really hope that there is a fix for it soon.
Anyway, one of the main problems I am having is the inacurate possitioning that it has of the vehicle. If I am at a corner of a block it shows I am about 100-150 feet behind where I really am, if I am on a service road, it shows I am on the main highway. Because of this the directions it is spewing out are totaly wrong, it says make a left but I should be making a right etc... Is there a way to adjust the sensitivity of it or teach it the actual position of where you are? I hope that can solve the problem. I have had 4 cars in the past 6 years with NAV and NEVER had even close to the issues with NAV that this POS does. Even my wife's little garmin is 10x more accurate as well as faster on responce that my $2k+ hunk of junk. Dont even get me started on street names.
_________________
04 V8 Reflex Silver/Anthracite with/all opt.
Back to top
Club Touareg Ad Bot
Club Touareg Staff
spockcat
Pictures: 18
Gallery pictures: 10
spockcat's gallery
Posted: Fri Jul 30, 2004 1:12 pm Post subject:
You need to calibrate your system. It isn't hard but the procedure isn't explained in the manual. When I get a chance, I will go out to my car, write it down and post it here. Won't be today though as I am riding a motorcycle today, not driving my car.
_________________
How to connect an MP3, XM or CELL to your Touareg Radio - TOUAREG DEADPEDALS ==> www.tm-techmark.com/tri.htm
Back to top
spockcat
Pictures: 18
spockcat's gallery
Posted: Fri Jul 30, 2004 4:30 pm Post subject: Calibrating your postion on the nav
First, you have to drive to a known intersection on the map, parking as close to the corner as possible. The best is a T intersection so you are not confused as to which road you are on at the junction.
Zoom the map in to 0.05 mile zoom.
Press the NAVI button.
Press the SETUP softkey on the right side of the display.
Press the POS. ON MAP softkey on the left side of the display.
Confirm that you are still zoomed in on the 0.05 mile level.
Using the softkeys on the left side of the display, rotate the cursor to the correct direction you are parked.
Using the softkeys on the right side of the display, move the cursor to the correct location you are parked.
Press OK.
You have now calibrated your position and direction of travel on the map. Hopefully you will have better accuracy with the nav system.
_________________
Back to top
4x4s
Pictures: 12
Gallery pictures: 12
4x4s's gallery
Posted: Fri Jul 30, 2004 10:05 pm Post subject:
Spock, you forgot the step about waving your hand out the window so the people behined you at the intersection don't just sit behind you and honk while you diddle with the nav controls.
_________________
'04 Touareg - V6, Bi-Xen, Reflex Silver with Anthracite interior
Back to top
spockcat
Pictures: 18
spockcat's gallery
Posted: Sat Jul 31, 2004 7:27 am Post subject:
Perhaps in Chelmsford there isn't a free intersection but here in Central CT we have enough of them that sitting at an intersection for 2 minutes isn't a big deal.
_________________
Back to top
4x4s
Pictures: 12
4x4s's gallery
Posted: Sat Jul 31, 2004 8:38 am Post subject:
Plenty of time in Chelmsford, but I was thinking of the original poster, who is in NYC. Of course he may have plenty of time when stuck in traffic...
_________________
Back to top |
2004 VW Touareg V8
w/air susp, DVD Nav, hitch, rear-locker, PIAAs, r-fog, asym mirror, paddles, keyless start
Amateur Radio equipment - Icom IC-2080h D-STAR/Radiall glass mount/TinyPac 4 APRS Modem - Icom IC-706MkIIg/AH-2B/SG-231/SCS PTC-II
2003 Audi Allroad turbo * 1978 VW Westfalia Deluxe (undergoing restoration and now off the road again |
