FAKRA Antenna cable color coding - Club Touareg Forums
post #1 of 28 Old 02-16-2012 Thread Starter
My God,it's full of stars
siberian's Avatar
Second Vehicle: 2008 V6
Does anyone know what the color coding is for AM and FM? I need to convert from dual FAKRA to DIN. My OEM colors are Tan and White. The pig tails I have are Yellow and Black (picture is just for reference). Any help appreciated (other than go and test them please)
siberian
Name:	Fakra to DIN.jpg
siberian is offline
post #2 of 28 Old 02-16-2012
sierradeux's Avatar
Smile
siberian
AM antenna is generally monpolar, whereas FM is bipolar.
Check that single bare wire lead for continuity with one of the FAKRA plug central electrodes, and you should have identified your AM antenna.
2017 Audi Q5 3.0 V6
2010 Touareg V6 TDI - in storage awaiting buyback
2008 Audi A4 S-Line 3.2 V6
2005 Touareg V6 - sold
1985 Porsche Carrera Cabriolet - sold
sierradeux is offline
post #3 of 28 Old 02-16-2012 Thread Starter
siberian's Avatar
You mean the blue power wire with one of the Fakra?
siberian
siberian is offline
post #4 of 28 Old 02-16-2012
nickm's Avatar
They both carry AM and FM, the lighter one is the main signal, when the OEM radio sense that the signal drops its switches to the other one (this is how the diversity antenna routing works).
--PREVIOUS TOUAREGS:
nickm is offline
post #5 of 28 Old 02-16-2012 Thread Starter
siberian's Avatar
Nick you're saying then it doesn't matter which gets connected to what? Reason I ask is that the DIN box has clearly marked AM and FM leads to connect the two OEM ones to. It then has a power lead (blue wire) which I assume is if you're not getting good enough reception and the DIN plug which goes into the HU.
TIA
siberian
PS I tried the blue wire to (knowing which one it is as it's labeled) center connector of the Fakra and I got nothing - didn't think I would somehow... so which wire is it...
siberian is offline
post #6 of 28 Old 02-16-2012
Isn't the blue wire/s power booster/s for antenna? Haven't looked at the drawings for a while but I kind of recall something like that in Elsawin
Walton AKA 92c2targa#119
2010 TDI Campanella White on Anthracite with Sport Package.
Other Rides:
Dodge Ram; BMW 328xi; BMW X3; 911 4GTS
92c2targa#119 is offline
post #7 of 28 Old 02-16-2012 Thread Starter
siberian's Avatar
Yes it's for boost or in the old days for the electric antenna which is why I can't understand what bare wire I'm supposed to check against the Fakra for continuity.
siberian
siberian is offline
post #8 of 28 Old 02-16-2012
nickm's Avatar
Here's more than you ever wanted to know about Touareg antennas:
Required Aerial mod for RNS510 Retrofit to T1 - myTreg forums
nickm is offline
post #9 of 28 Old 02-16-2012
OILSLURPER's Avatar
Siberian, you are indeed a man of perserverance! Good onya for not letting the m@th@f@cker of a HU get you down man. Mine is still good by the way. BTW - NickM clearly has a Touareg fetish digging up some stuff.....which given this site, seems healthy.
2007
- 4xmotion 3.0 V6TDI - never missed a beat.SOLD - 04/2012
A truly great vehicle
!!!! replaced with Passat and Navara
2007 - VW Crafter 3.5 MWB 2.5 TDI (Steinbauer ECU). German build.
2006 -
VW Caddy 1.9 TDI 6-spd manual...retired. Polish build.
2009 - VW Caddy Maxi 1.9 TDI DSG, Polish build,
2011 - VW Passat 125 TDI Highline DSG..... German build. Runs on fumes.
2012 - Navara D22 2.5 TD dual cab, chipped +400nm, 3" hi-flow exhaust, 3" lift (boat tractor). Jap build.
OILSLURPER is offline
post #10 of 28 Old 02-16-2012 Thread Starter
siberian's Avatar
Nick I just have AM and FM with a DIN going in to the HU. I'm not a radio ham so I don't really know which goes where but from looking at the DIN connector I'm not sure it makes a difference. Appreciate the pointer but can't understand how it relates to what I have.
Slurper, this is the new unit. The Maisun is working perfectly!
siberian
siberian is offline
Ideas for Routing Satellite Antenna & Cable beartooth91 Mobile Electronics and In Car Entertainment 9 05-20-2011 03:42 PM
Fakra quadlock connector ? NapaCoach Mobile Electronics and In Car Entertainment 1 01-04-2009 11:10 AM
headunit antenna cable Upin96 Mobile Electronics and In Car Entertainment 3 06-08-2007 06:41 PM
Running Coax and Control cable for external HF antenna. V10-downunder General Maintenance & Repair 3 10-25-2006 09:06 AM
Fakra Connectors blackheathen Mobile Electronics and In Car Entertainment 3 09-08-2006 06:17 AM
