Old 08-13-2008   #51
blackheathen
Bit more info on the canbus adapter:
The canbus adapter merely translates canbus 1.6 to/from 2.0 messages for the RNS only - i.e it does not do anything to the overall canbus as it acts as a filter between them.
blackheathen is offline   Reply With Quote
Old 08-13-2008   #52
Singh
Singh's Avatar
Images: 13
i'm keen on installing the rns10 so will lean on your expertise BH. as for the reverse camera, i have the rear spare wheel mounted so cant put the camera in the handle. did u source ur rns10 unit locally?
V10 TDI with Sat Nav, paddle shifters, rear diff locks, hinged spare, phatbox ...
Had V6 petrol on Pirelli AT's with Sat Nav, Rear Diff locks, Bluetooth & Phatbox.
Singh is offline   Reply With Quote
Old 08-14-2008   #53
blackheathen
Singh,
no I didn't source locally. My supplier no longer has any - VW tighened up the supply I believe.
vwnavi has a supplier who by all ccounts is very reliable - check here:
RNS 510 brand new - VWnavi.com - Your Source for Satellite Navigation Systems in VAG Automobiles
And his prices are very good. Believe he gives a warranty and ships carefully.
You want the Euro version. 7L6......A. The Touran also fits, but I'd stay with a Touareg version. vwnavi has the part numbers in an FAQ.
Glad to help in getting you going.
BH
Old 08-19-2008   #54
strmrdr81
Send a message via AIM to strmrdr81
I too have been considering getting the RNS 510. I just got an 08 black V8 Touareg with Tech package. I find the navi not as good on other similar vehicle and want to upgrade.
I'm under the impression that the 08 models are on Can bus 2.0 already and so the RNS 510 will simply bolt in. However do I need to do any coding to the unit? Will the Back-up cam and and steering wheel functions still work?
Is this something the VW dealers will do for you?
thanks
08 Black V8 ,Tech pkg, Air suspension,
strmrdr81 is offline   Reply With Quote
Old 08-31-2008   #55
EARL97850
EARL97850's Avatar
Does the unit work in the older Tregs and still enable the steering wheel controls?
Cya
'05 VW Touareg V6 Campanella White/Anthracite
'02 VW Jetta GLS TDI Galatic Blue/Beige
EARL97850 is offline   Reply With Quote
Old 09-01-2008   #56
Singh
Singh's Avatar
Images: 13
yes, for older tregs you need a canbus adapter, small module which takes care of the difference between the newer canbus 2 and the old one
Old 09-01-2008   #57
Jakarta Expat
Jakarta Expat's Avatar
Well if you switch over to the RNS 510, if you find it cheap, pick it up. Over here I was quoted the thing as an option the RNS 510 was quoted at USD 3750 and thr backup camera quoted at 850 USD. CEO of VW Indonesia talked me out of it since over here the format for the nav would not work here so he talked me in to a all in one unit made by a VW OEM supplier with Nav unit, Bluetooth, review camera, IPOD connector plus able to connect and hook up to the steering wheel controls, all for roughly 1000 to 1500 USD installed. I'll know in mid November if this solution works.
Jakarta Expat is offline   Reply With Quote
Old 09-09-2008   #58
Singh
Singh's Avatar
Images: 13
would be good to know what this OEM unit is, keep us posted.
Old 09-10-2008   #59
abarna21
BH
do you still gave the navi +cam for sale?
2008 T2 V6 no Navi yet
2007 Passat 2.0 Turbo
2000 GLI Cabrio
2007 Suzuki Boulevard
abarna21 is offline   Reply With Quote
Just bought mine BabyBlue04 General Touareg Discussion 5 12-17-2007 09:55 PM
Just bought an 04. rochestergeek General Touareg Discussion 11 11-30-2007 10:06 AM
Am I getting a good deal on 04V8? v8lover General Touareg Discussion 5 11-21-2004 07:49 AM
Just bought a V8 flip1999 General Touareg Discussion 10 09-19-2004 08:08 PM
Why I bought a V10.. BoostAddiction General Touareg Discussion 4 08-22-2004 09:55 PM
