Having suffered the violent 4-5th gear changes for a couple of years I have finally had enough and want to get the valve chest rebuild done. Can anyone recommend anyone in the UK, good or bad, your experiences are welcome.
The links I got were:
Beds Auto Transmissions, £395 + VAT (£474)
There is a rebuild service on Ebay @£700
Valve bodies UK £463.25+VAT (£556) recondition or new for £808.25+VAT (£970)
I spoke with Beds, and all seemed good, so was planning on using them.
Got the car in the garage last night, raised a few inches and stands in. Tray off, is there a way to remove the cross plate that holds the plastic tray middle support? It gets in the way a bit but undoing the nuts at each end gives a little bit extra fiddling room, but it would be nice to get it completely off. I just can't seem to get it out either way.
Sump plug out and first drain, cracked all the bolts, but one and tilted for extra drain. Forgot another glug comes down when you remove the filter.
Allowed to drain and mopped up the filter spill. Took pictures and made notes for all the electrical connectors.
Now struggling to get the connectors off and not wanting to break anything I called it quits for the night. Will resume tonight.
Sussed it a bit more brute force and going up the side was a red herring.
All you need to do is lever the black connector down using a scribe, and a precision screwdiver in behind the green connector and it simply pushes out.
