Rear Passenger Wheel locked up.... - Club Touareg Forums
post #1 of 20 Old 05-14-2012 Thread Starter
Send a message via AIM to NYTouaregGirl
Hi Everyone,
Had a strange thing happen friday- my rear passenger wheel locked up. The other 3 would roll fine, but the one wouldn't. If you put it in drive or reverse, the three tires would roll along normally, and just skid the rear passenger one.....
I checked the e-brake, differential etc., nothing appeared out of the norm. No idiot lights on either, all seemed well.
Had the flatbed come take it to the dealership, such a sad sight! As of now, dealership still hasn't gotten back to me on it. Saw one of the VW tech's Friday when it was being unloaded off the tow truck, he had no idea what it could be but said it didn't sound good......
It's an 08 V8 with approx 43,000mi, I'm still under warranty till November 2012 or 50k.
A friend of mine said maybe a frozen caliper? Just had new rotors and pads put on about 3,000mi ago..... New tires installed about 500miles ago.....
NYTouaregGirl is offline
post #2 of 20 Old 05-14-2012
The parking brake comprises two "old fashioned" brake shoes that operate inside a drum that is an integral part of the rear brake discs/rotors.
Did the wheel lock up as you were driving along or did this happen when you released the parking brake?
If it was when you released the parking brake then I wonder if these shoes have locked on inside the drum on one side of the car?
post #3 of 20 Old 05-14-2012 Thread Starter
As I was driving it out of my driveway. I had noticed a squeaking noise the last time I drove it, but attributed it to the fact I hadn't driven it in a week or so and the fact that it had been raining a lot that week. I usually get a little noise as the rust spots wear off the rotors. Friday, I started it up and put it in reverse that's when I first noticed the wheel was dragging. I put it in drive and it locked up going forwards as well. As it was bein pulled up onto the flatbed, you could visually see all of the other wheels turning as usual.... Except the one...
post #4 of 20 Old 05-14-2012
Moderator
hedditch's Avatar
I am with Nooby... check your park brake...
Stuart..
2008 V6 TDI, Air Suspension, ACC with Front Assist, Paddle Shifter, RNS510, Leather Seats, BI Xenons, 4 Zone Climatronic, Sunroof, Towbar & Trailer Module,Fiscon Bluetooth. Reversing Camera, Front Fog Lamps Xenon 3000K, Redarc TowPro Brake Controller, T1 Door Warning Lamps, T1 Under Seat Drawer, Alloy Skid Plate, 5ton Winch, Cayenne (Green Dot) Front and Rear Sway Bars, Performance Tune by Oettinger, Retrofitted 6 Piston Brembo Front Brake Callipers, Custom Sports Steering Wheel
hedditch is offline
post #5 of 20 Old 05-14-2012
If it is the park brake, then it should not take very lomg to remove the wheel, remove the disc/rotor and check what's going on inside the drum. 30 minutes?
The mating surfaces of the drums rust very badly as there is no friction from the brake shoes to clean them because the parking brake is only applied when the car is stationary.
post #6 of 20 Old 05-14-2012
Since you changed the rotors as well as the pads, I would suspect that one of the 2 caliper carrier bolts has come loose. VW recommends that they are always to be replaced after removal as they are stretch bolts and are torqued to about 200 ft lbs. I had a BMW that locked up like that due to caliper becoming misaligned because of a loose bolt. This was also just after a brake overhaul.
Good luck and let us know what you find.
Jim X
Jim X
2005 V8 Touareg
2004 Phaeton
Maitland, FL
jaxander is offline
post #7 of 20 Old 05-14-2012
Touareg: 2007 V6
One member made a calculation using Grade 12 bolts and the torque was at the margin before going plastic. But the ones I got were Grade 10, so these were torqued into the plastic region at 200 lb/ft.
Wasn't it strange that VW did not specify angle for these, if these are TTY bolts? The bolts for the front seat may be the same. Zinc anti-corrosion coating or TTY I will always replace them. Dealers go against VW recommendations and do not replace these bolts. But go with what the repair manual says.
For OP another possibility may be mis-adjusted parking brake, especially with a new rotor.
SamT is offline
post #8 of 20 Old 05-14-2012
Touareg: 2007 V6
Were there signs of the rotor swept surface overheating (turned blue?) Either the caliper or parking brake can cause the wheel to seize.
The dealer can loosen the bleeder screw, and if the wheel turns then the caliper is the problem. They can also check the parking brake.
One member had a shop replace the rear rotors/brake pads (? IIRC) and the shop did not readjust the parking brake like they were supposed to. The brakes locked up and the shop had to perform warranty service.
SamT is offline
post #9 of 20 Old 05-15-2012 Thread Starter
You all are right on the money. I stopped at the dealership yesterday on my way home and sure enough.... the parking brake is the problem. They tried to quote me $400+ to fix it! After some discussion and my explaning to them that the brakes had all been replaced less that 3k miles ago (at another VW dealership) they agreed that perhaps the other dealership messed up when reinstalling the e-brake. I just faxed them over the invoice from the brake job, and they're going to contact the other dealership and VW to see if they'll cover it under warranty.
Thanks to everyone, as always! This forum is great!
post #10 of 20 Old 05-15-2012
Are they checking the parking brake on the other side as well to make sure that whatever has been done wrong on the one side has not been repeated on the other?
Rear Passenger door will not unlock maypaul General Maintenance & Repair 8 01-03-2013 05:50 PM
Passenger Rear Light LShep General Maintenance & Repair 2 10-13-2011 09:20 AM
Steering Wheel locked Sevoook General Maintenance & Repair 2 04-11-2011 08:40 PM
noise from the rear passenger side eggyacid General Maintenance & Repair 12 09-13-2010 07:40 AM
Dent in rear-passenger door/Rear Qtr panel Diablonyc2 General Maintenance & Repair 2 07-09-2010 08:16 AM
