Maximum Tyre Sizes - T1 & T2 - Page 5 - Club Touareg Forums
post #41 of 282 Old 12-17-2010
I just ordered Hankook DynaPro ATM RF10 P265/65R-18. I have not received them yet.
Am I hearing that the max is 265/60/18?
I thought someone on a prior post said the max for this tire is 265/65 on 18 inch rim.
I have a 2005 Touareg with air suspension.
andrew8008 is offline
post #42 of 282 Old 12-17-2010
Too Cool to Leave School
Anand's Avatar
Second Vehicle: 2004 V8
Andrew,
I had a set of the 265/65s ordered from Discount as of yesterday, they called back today to tell me that their inventory online was incorrect and they are actually out of stock for "at least 2 weeks"... I opted for 285/60 Terra Grappler's and to run 5mm spacers on the front...
The 265/65s will fit all Touareg's although you will have rubbing on diesels
Anand is offline
post #43 of 282 Old 12-17-2010
Anand... Thanks for the reply. Glad to hear that they will fit.
I originally ordered from Discount Tire Direct and got a call saying that they were out of stock. Not sure why they don't update their website.
I got lucky and found 4 tires at Gripston - Welcome yesterday.
post #44 of 282 Old 12-17-2010
OILSLURPER's Avatar
US member had 65 profile I have 60 profile. I have my doubts with 65 as they may rub the front intercooler slats inside the front end of the wheel well. 60 gets no rub.
2007
- 4xmotion 3.0 V6TDI - never missed a beat.SOLD - 04/2012
A truly great vehicle
!!!! replaced with Passat and Navara
2007 - VW Crafter 3.5 MWB 2.5 TDI (Steinbauer ECU). German build.
2006 -
VW Caddy 1.9 TDI 6-spd manual...retired. Polish build.
2009 - VW Caddy Maxi 1.9 TDI DSG, Polish build,
2011 - VW Passat 125 TDI Highline DSG..... German build. Runs on fumes.
2012 - Navara D22 2.5 TD dual cab, chipped +400nm, 3" hi-flow exhaust, 3" lift (boat tractor). Jap build.
OILSLURPER is offline
post #45 of 282 Old 12-17-2010
31.6 inches is the safe max diameter on a 265/70/17 and 265/65/18 is identical in width and diameter so you should be ok.
Tire size calculator
post #46 of 282 Old 01-10-2011
Mountain_Smith's Avatar
Touareg: 2008 V10 TDI
Here are 265/60 18's on my 2008 V10. Goodyear lists this tire at 30.5"
265/60 18 Silent Armors
You would not be able to step up to the 65 profile version of these tires without modifications on a 2008 V10.
Also, the wheel well liner on my 2008 does not seem to have the give, or extra space behind the intercooler vents that earlier ones do for the 'screw mod': 295/45R20 They fit!
Mountain_Smith is offline
post #47 of 282 Old 01-10-2011
Porsche Cayenne 5 Spoke Rims...
-Size: 18x8
-Offset: 57mm
-Backspacing: 6.8"
-Bolt Pattern: 5-130
-Weight: 32.4lbs.
-Finish: Silver w/Machined Lip
The Ecsta STX KL12 is Kumho's Street/Sport Truck All-Season Radial Tires...
-275/55R18
-UTQG: 420AA
-Max Load: 2601 Lbs
-Tire Weight: 39 Lbs
Mike
MacTDI is offline
post #48 of 282 Old 01-11-2011
2006 touareg V8 with 265/70/17 BFG ATs and i rub in the front. But not enough to make me care
ENGINEer is offline
post #49 of 282 Old 01-11-2011
I saw a recent post where someone fitted 5mm spacers to sort that - they could still use the exisitng wheel studs too.
post #50 of 282 Old 01-11-2011
Anand's Avatar
If anything I would say the 5mm spacers I needed to fit my 285/60/18s are causing more rubbing (by moving the wheel outwards), as I have rubbing on the back of the fender liner (nearest the doors) at 1/2 to 3/4 turn; very light contact (although, you can hear/feel it)
Anand is offline
For Sale: OEM 17" Makalu wheel & Tyre seafarer28 Classifieds 14 01-14-2011 10:55 PM
Best tyre option & shop in Melbourne? benasmith Australia & New Zealand 21 09-20-2010 06:54 AM
Maximum Lowering Limit? BANKO VAG-COM 42 09-16-2010 09:11 PM
OEM crossbar maximum vertical stress limits CsTDI General Maintenance & Repair 6 07-02-2009 07:40 AM
FOR SALE - one 17" Wheel & Dunlop Tyre BigRizz Australia & New Zealand 3 02-27-2008 05:14 PM
