Maximum Tyre Sizes - T1 & T2 - Page 4 - Club Touareg Forums
post #31 of 270 Old 10-08-2010
norsecarnut's Avatar
Originally Posted by nickm View Post
I'm shopping out 315/35/20 for the rear, going to stick with 275/40/20 for the fronts. Diameter of both sizes is identical.
As per our discussion, is there any reason at all the very cool Cayenne staggered set up of 20" x 9"fr/10" rear wouldn't work? The 20" "sport Techno" would look HOT.
I also like the oversized 20" size of 285/50x20 (9"rim width). I like this for the suv because while it is a nice rim size that is visually proportional, you still get more sidewall than a stock 19" provides! It's also a bit wider, but not so wide as to cause problems. I used the Toyo S/T for a while and they were great, however there is an awesome Yokohama tire in W rating (168mph) that would be great too - it's designed for heavy fast suv's.
This one is ideal for 9" rim and more in keeping with stock Touareg size specs at 275/50x20
Yokohama ADVAN S.T.
Current:
2008 Audi S4 Avant mt6
2008 BMW 535xi Touring 6 spd
2007 Land Rover Discovery 3 modified
2004 Land Rover Discovery 2
1996 Land Rover Discovery 1 / 230,000 miles
norsecarnut is offline
post #32 of 270 Old 10-08-2010
My God,it's full of stars
siberian's Avatar
Second Vehicle: 2008 V6
I assume none of you do or are faced with serious snow conditions as those size rims and tires will be the pits in those conditions - unless of course you use monster low pressure tires like the do in Iceland or in tundra. Just my 2 cents
siberian
siberian is offline
post #33 of 270 Old 10-13-2010 Thread Starter
AndrieK's Avatar
Touareg: 2004 R5 TDI
Originally Posted by findre View Post
Had factory 19's, but went into shock when I found out the price of new Michellins after only 14k.
I am on my second set of 22" Replaced my Kohans with Victor Racing. 285/35R22 v106's First set of Yokos went 46k until they were racing slicks. New set is same size, but are Nexen. Tires are junk but came with rims with 5k on them and they were practically for free, so I'm not complaining.
OK you're confusing the crap out of me...
Your first set was OE 19's with Michelin tyres (I assume 275/45R19)
Second set was Yokohama's in 285/35R22 on Kohan wheels
Third set was Nexen in 285/35R22 on Victor Racing... Right...?
Do you know what the spec (width and offset) for the 22" wheels are?
AndrieK is offline
post #34 of 270 Old 10-13-2010 Thread Starter
AndrieK's Avatar
Originally Posted by siberian View Post
Andrie, unless someone preempted me, please add: 255/50R19 on Nokian WR G2 on my 2008 V8 A/S
Supplier: MK Tire, NJ, price $203/tire plus ship (made in Russia)
siberian
Greg, interesting that I can only find that size on MK Tire's website and not on any of Nokian's official sites. Wonder if this has been discontinued, maybe...?
Anyway, I added yours.
AndrieK is offline
post #35 of 270 Old 10-20-2010
rskreli's Avatar
Originally Posted by Singh View Post
Here's some clarification on the Conti Cross Contacts:
30.04inches or 763mm
Rim: VW Manhattan 18"
will fit T1 V10 without any rubbing, but will slightly rub - as reported by Wannabe, on the T2 V10. The rubbing isnt on the vents as such but on the slight protrusion - the wheel well plastic has been replaced with a softer material in the T2s that protrudes a little bit more than what we have in the T1s.
I assume VW have made this change to soften the hit from small rocks and pebbles which are thrown up by the tyre into the wheel well.
how about 2004 v8 with air suspension??????
04 TrEg v8, nav, air suspension ,etc,etc...
KeeP On TrEggInG
NeW YoRk StAtE Of MiNe
rskreli is offline
post #36 of 270 Old 10-20-2010
Singh's Avatar
Second Vehicle: 2015 V8 TDI
you should be fine upto 265/60/18
V8 TDI R line MY15, White with Panoramic roof, VW towbar and the lot.
V10 TDI, MYO6 on Conti CrossContact 255/60/18s with RNS510, Paddle Shifters, Rear Diff lock, Mounted Spare, Phatbox, Bluetooth, 4 Zone CC, Keyless, AFS Xenons, TPMS, Easy Entry/Exit, Twin Batteries, Air Suspension, Sunroof, Icom IC440 UHF radio...
Singh is offline
post #37 of 270 Old 10-23-2010
ScottishVW's Avatar
This morning I had 275/40/20 tyres on my Reg and now I'm sitting on 275/55/20. In my opinion this is pushing it because when I turn sharp corners, I can hear and faintly feel the tyre rubbing on the wheel arch. I really hope this isn't a big deal, as I don't feel like spending another $1,000 to get new ones fitted again. What do you guys think? Think the tread will wear down enough eventually? lol
ScottishVW is offline
post #38 of 270 Old 10-23-2010
I'm thing of getting some 275/50 on 20" rims.
Can you post some pictures of your 275/55/20 set-up? Thanks.
Mike
MacTDI is offline
post #39 of 270 Old 11-17-2010
Too Cool to Leave School
Anand's Avatar
Second Vehicle: 2004 V8
wow a 275/55/20!? I'm sure that was a fairly readily available size (IIRC its the stock Tahoe/Suburban LTZ size)
the 275/55/20 comes out to be (mathematically) a 31.91" tire, the largest "reliable" on a non-TDI Touareg is around a 31.6" (~265/55/20) and those are at 265 widths. I highly doubt you are rubbing on the wheel arch, unless your truck is lowered considerably, however, more than likely rubbing on the fender liner. I would also ensure you have suitable clearance on the inside of the tire w/ the suspension components
Anand is offline
post #40 of 270 Old 11-17-2010
No as it is probably the inner wall of the tyre that's rubbing, not the tread surface.
Get out and get under with the steering on full lock and see where the rub marks are on the plastic wing liner and the tyre, amd also the suspension as suggested above too.
For Sale: OEM 17" Makalu wheel & Tyre seafarer28 Classifieds 14 01-14-2011 11:55 PM
Best tyre option & shop in Melbourne? benasmith Australia & New Zealand 21 09-20-2010 07:54 AM
Maximum Lowering Limit? BANKO VAG-COM 42 09-16-2010 10:11 PM
OEM crossbar maximum vertical stress limits CsTDI General Maintenance & Repair 6 07-02-2009 08:40 AM
FOR SALE - one 17" Wheel & Dunlop Tyre BigRizz Australia & New Zealand 3 02-27-2008 06:14 PM
