Maximum Tyre Sizes - T1 & T2 - Page 27 - Club Touareg Forums
post #261 of 282 Old 10-03-2016
MmmBoost's Avatar
Touareg: 2009 V6 TDI
A 31" diameter tire on an 17/18" wheel has the same amount of sidewall no matter what the width. Most people go with wider tires for more floatation. Narrow tires would tend to sink more in softer terrain.
The 2nd number in the tire size is not a measured number but a ratio of width to sidewall height. So a narrow tire would need a higher number to equal a wider tire of the same overall diameter.
These are nominal numbers....
235 = 235mm wide
75 = 0.75 x 235 = 176.25mm tall sidewall (nominal)
17 = 17" wheel
So 17" => 431.8mm + 176.25 + 176.25 = 784.3mm => 30.88" Diameter
265 = 265mm wide
65 = 0.65 x 265 = 172.25mm
so.... 17" => 431.8mm + 172.25 + 175.25 = 776.3mm => 30.56" Diameter
It's either gotta be really really clean....or really really dirty.
MmmBoost is offline
post #262 of 282 Old 10-03-2016
I can understand the idea of "flotation" but not sure it makes as big a difference as some think. Dakar cars use 235/85r16 tires and they see tons of sand. It just seems that some of the fitment issues could be avoided by sticking with OE widths and going to a higher aspect ratio tire for height. Also tire weight seems to go up much faster when increasing width than when increasing height.
For instance the Cooper AT3 in 235/75r17 weighs 35lbs and in 265/65r17 weighs 40lbs. That 5lbs a tire is a lot, especially if you consider the 1lb rotation weight = ~10lbs in the car. For the Coopers that's like adding 200lbs into the back.
Just trying to get people thinking about sizes other than the 265/65 that is so prevalent.
overlandcayenne is offline
post #263 of 282 Old 10-20-2016
Kristoffer Batto's Avatar
Touareg: 2007 V8
I have 265/60r18 (30.5" diameter) and no rubbing at all.
Kristoffer Batto is offline
post #264 of 282 Old 11-06-2016
ajnanyc's Avatar
I really like the new G2 Terra Grapplers on 17" wheels that replaced the stock 19".
ajnanyc is offline
post #265 of 282 Old 11-06-2016
thisbenguy's Avatar
Touareg: 2009 V6
Do you have any rubbing at full lock with the 70?
'09 Black on Black | Paddle Shifters | Aspherical Mirrors | ROW Transmission | Yellow Fogs | Dual Rear Fogs | PIAA 510's in the grill | DRL disable w/ Euro Switch | Interior LED's | Quad Brake Lights
thisbenguy is offline
post #266 of 282 Old 11-07-2016
ajnanyc's Avatar
No rubbing whatsoever, even with air set to low in sport mode. The only negative being the substantial decline of MPG.
ajnanyc is offline
post #267 of 282 Old 01-09-2017
KO2 265/65/17
Hi all
I've just got my hands on a UK spec 2005 2.5tdi manual with steel suspension and canyon 17 inch rims. I'm loving it so far but the tires are cheap road tires which are pretty shot and I want to get it out in the mud so I'm going to swap the whole lot for a set as big a set as I can, Ideally BFG KO2's in 265/65/17 like yours tzwizard. From reading this and multiple other tyre threads I've established that 265/70/17 won't fit because of the IC vents and mine is an earlier model so im not sure if the IC vents are in the same position as tzwizards being a 2010 or if the wheel wells are the even the same dimensions? Ultimately has anyone fitted this size BF Goodrich KO2 or any other aggressive tyre in the larger sizes to a t1 tdi on 17's?
Thanks!
Bonzo is offline
post #268 of 282 Old 01-09-2017
Before you do anything at all, do you know if your engine has EXACTLY the right oil in it to avoid premature camshaft lobe wear? Even VW dealers get it wrong.
VW 505.01 or 506.01 - nothing else will do.
Also read this thread carefully if you haven't seen it - you'll probably learn a lot:
Buying a used Touareg. What to look for. - myTreg forums
color="black"> word word word
post #269 of 282 Old 01-15-2017
noobytoogy
Thanks for the heads up! It seems there is a whole load of potential expensive problems to bare in mind.. passed on the car, it was cheap but had no history..
Bonzo is offline
post #270 of 282 Old 02-16-2017
Read through the thread, can anyone tell me if they've had any luck with a 255/70/18
I've got an 05 touareg v8 with air suspension and stock wheels
Sent from my SM-N920T using Tapatalk
deh2002 is offline
For Sale: OEM 17" Makalu wheel & Tyre seafarer28 Classifieds 14 01-14-2011 10:55 PM
Best tyre option & shop in Melbourne? benasmith Australia & New Zealand 21 09-20-2010 06:54 AM
Maximum Lowering Limit? BANKO VAG-COM 42 09-16-2010 09:11 PM
OEM crossbar maximum vertical stress limits CsTDI General Maintenance & Repair 6 07-02-2009 07:40 AM
FOR SALE - one 17" Wheel & Dunlop Tyre BigRizz Australia & New Zealand 3 02-27-2008 05:14 PM
