How to repair / refurbish your air suspension compressor for $40 - Club Touareg Forums
post #1 of 15 Old 04-11-2016 Thread Starter
Looking at this site makes me think anyone with an older car on air should consider refurbishing their compressor regardless!
Andy ships:
http://www.bagpipingandy.com/
color="black"> word word word
post #2 of 15 Old 01-03-2017
compu_85's Avatar
I bought one of his kits over the summer and finally got around to installing it over New Years. It's a very complete kit, and the install is straightforward.
Before the compressor was getting rattley - not super surprising as this is an 04 with 160k miles. With the new piston ring the compressor is barely audible!
-J
04 Touareg V10 TDI - 150,000 miles
12 Passat TDI - 92,000 miles
99.5 Jetta TDI - 305,000 miles
91 Mercedes 350 SDL. Yes, it bent the rods.
91, 92 Jetta ECOdiesels. Gone and missed.
compu_85 is offline
post #3 of 15 Old 01-04-2017
Did you disconnect all of the airlines into the valve block to get the compressor to your bench?
2005 V8 - Reed Green, Air Suspension, Dragline skid plate, Hankook Dynapros on 18" Karthoums
alhutch is offline
post #4 of 15 Old 01-04-2017
compu_85's Avatar
No, I only had to unhook the brown line (spare tire filler) and the black line to the valve block (compressor output). To get the black line out I had to unhook the compressor from the bracket, there wasn't enough clearance.
I cut the clamp off the larger black intake line's rubber union by the wheel well and disconnected it there, it was easier to deal with that line off of the truck.
Because I didn't disconnect the valve block the suspension didn't deflate.
-J
compu_85 is offline
post #5 of 15 Old 01-04-2017
Singh's Avatar
Second Vehicle: 2015 V8 TDI
Andy ships:
Thanks, this is worthwhile investment
Singh is offline
post #6 of 15 Old 01-06-2017
Hi guys,
New to the forum had a 2005 V8 with spring suspension best vehicle I've ever had. A accident later I have no a (new to me) 06 V8 with air suspension..Enter the issues......Only problem yet has been the "Running gear fault (workshop) " the compressor is noisy and sounds sick to me. All the air shocks were replaced 1000 miles before I bought it. Today first day in snow for me w the reg as well as the regs first time seeing cold temps it resided in Miami before coming to mo. it was 17 today I take off for work and the fault was same but in red and and said (stop) instead of workshop. The front of the vehicle lowered the the stops....In comfort mode auto height. Stopped the car turned on and off and let it warm up a little more ...Front raised and I went to work...Let the reg warm up tonight before leaving work ..No fault ....I get the running gear fault regularly. I feel as though the reg takes a long time to lower or raise... I'm thinking compressor....Any ideas
Puffken is offline
post #7 of 15 Old 01-06-2017
compu_85's Avatar
If the compressor is noisy replace the piston ring. Heck, I'd say most T1s at this point would benefit from a replacement piston ring.
Our truck used to take 3 compressor cycles to fill the air tanks (the compressor has a temp sensor and turns off when it gets too hot). Now it does it in one cycle
As always, start with a full VCDS auto scan when working on a Touareg. That will let you know exactly what the computer is upset about. "Running Gear Fault" can be caused by many different things.
-J
LauriJT likes this.
compu_85 is offline
post #8 of 15 Old 01-06-2017 Thread Starter
I may be wrong, but I seem to recall there is a dessicant pack built into the air system which one or two people have had to replace when moisture defeated the pack and froze, but if your car was in a hot, dry climate . . .
Anyway, as above, start with a full VCDS scan.
post #9 of 15 Old 01-06-2017
compu_85's Avatar
I was going to take the pack out of my compressor and bake it, but I saw no evidence of moisture contamination in the system. If I was doing that I'd want new seals for that area of the compressor (I presume it has o rings on it too?)
compu_85 is offline
post #10 of 15 Old 01-06-2017
Thanks for all the help 😊
Puffken is offline
