#1 |
Help me choose right wheel and tire combo:
I've decided on the oz canyon, more than likely will have them powdercoated a satin black (car is offroad grey). Heres the dilema. I really like the look of a 20" rim, but living in colorado i'm constantly in the mnts snowboarding, and do some light off roading during summer months. Spoke with tirerack at length, there is the BF Goodrich Alterain TKO available in a 285/55/20 or, i can just do and 18" and go with the Bridgestone Revo Dueler in a 265/70/18.
Thoughts? How do you think a 20" wheel will look in a 55/20 offroad tire? Will i sacrfice at all or do you think i will be fine? Lastly, thoughts on the oz's in a satin black on an offroad grey? Appreciate the advise! |
#2 | |
Re: Help me choose right wheel and tire combo:
Now the tires. For good overall performance, VW recommends tires with a diameter of 28.7"-29.5". The 285/55-20 BFG AT's are 32.8" in diameter and weigh 50 pounds! They also cost $328 each! For offroad, I run Bridgestone AT REVO's in 265/65-17 (great tire, BTW) which are 30.5" in diameter. I can't imagine a tire 20mm wider and more than 2" larger in diameter fitting on the Touareg without some serious clearance issues. Also, even if they fit, your onroad handling will be seriously compromised - slower acceleration, longer braking distance and general sluggish/sloppy handling due to the tire diameter and significant increase in unsprung weight. The 265/70-18 REVO's are almost the same - 32.6" in diameter. I would suspect some clearance issues. If you don't have a V10, I would consider the 265/65-17 REVO's for very good overall on and off road use in dry, wet and snow. They don't look bad, either: ![]() HTH |
#3 |
I went with these Ronals with Hankook Ventus St RHO6 tires and it looks awesome.
Hankooks are quiet, look great and reasonably priced too!!
2007 Reed Green Anthricite Cold Weather Pack 3.6L FSI V6 Tow Package 20" Ronal R43 Wheels w/ Hankook Ventus ST RH06 Tires Xenon headlights |
#4 |
What size tires? Any pics on your car?
#5 |
I almost went a very similar route with my wife's Treg.... but didn't (still kind of wish I had). The BFG AT's in the 285/55R20 probably won't fit w/o some decent massaging to plastic inside the wheel wells. A good alternative, and a better tire IMO, will be the Nitto Terra Grappler in the 285/50R20 size. It measures 31.26 height with a 11.69 section width. It should sneak in there, but the offset of the OZ may affect that. I have 265/70R17 which are .25 taller but 1" narrower, they clear everything just fine.
Black wheels? Very nice! Lastly, IMO the Touareg V8 is overgeared with the 4.56 diffs and 28.5" tires. It takes to the 31.5" tire very well
Brian 04 VW T-Reg V8, 93 VW Corrado Syncro 3.0L, 93 Toyota Land Cruiser trail rig, 80 FJ40 Cruiser, 51 Jowett Jupiter Roadster |
#6 |
My tire size is 275/45R20XL
Here's a link to Hankook: http://www.hankooktireusa.com/produc...ail.asp?pid=12 I will post a picture of my rig soon but it is the same color as the one above. Reed Green. The wheels are easy to clean too!!!! Cheers
| Thread Tools | |
| Display Modes | |
| 275/45/R20 Tire on a 20" Wheel | Monk | Running Gear | 1 | 06-18-2007 03:37 PM |
| Best tire / rim combo for towing? | marc3oh | Running Gear | 2 | 02-22-2007 02:01 PM |
| Please Help With Snow Wheel/Tire Combo | 1BadAssT-Rex | Running Gear | 12 | 11-29-2006 10:56 AM |
| 17" wheel and tire weight | colorado dreams | Running Gear | 0 | 05-16-2005 03:45 PM |
| Tire and Wheel Protection | ike | Running Gear | 2 | 12-15-2004 10:19 PM |
Other
Social Knowledge
