Go Back   Club Touareg Forums > Club Touareg Technical Forums > Running Gear
Old 06-19-2009   #11
v10treg's Avatar
Images: 12
No? Enlighten me? I hate it when the suspension tries to compensate when you jack up each corner You can press the "lock" button for the air suspension, but it only works if your using "above normal height"....
v10treg is offline   Reply With Quote
Old 06-19-2009   #12
Vegas Matt's Avatar
Press and hold the lock button for about 5 seconds, and a prompt will show up in the MFI that you're in Jack mode. This will keep the Touareg from trying to auto level. Jacking an air-suspended Touareg without this mode is downright dangerous, as it can shift and fall off the jack. It has also been said that the air suspension can be severely damaged if the Touareg is lifted off the ground (ie on an automotive repair lift) without putting it in lock mode.
Hope this helps,
Matt
Bye bye Blue...
Old 06-19-2009   #13
v10treg's Avatar
Images: 12
I'll try that, thanks for the info Matt.
Old 06-28-2009   #14
xonetruthcrewx's Avatar
Send a message via AIM to xonetruthcrewx
I have these tires. Good for summer use. Good in rain. Great dry grip.They do have an M+S stamp, but trust me, they suck in the snow. My main complaint, they are LOUD. Tons of road noise. I have run mud tires on other cars that are quieter than these. My BFG AT's on my Titan are quieter.I cant wait to replace them. And that will be another 3-4 months. Right now I have about 25k miles on them. So I would say maybe 35k miles out of them. Next tire will be a Cooper Zeon LTZ in a 275/45/20. I cant wait!
xonetruthcrewx is offline   Reply With Quote
Old 06-28-2009   #15
Touareg: 2008 V10 TDI
Originally Posted by xonetruthcrewx View Post
I have these tires. Good for summer use. Good in rain. Great dry grip.My main complaint, they are LOUD. Tons of road noise. Next tire will be a Cooper Zeon LTZ in a 275/45/20. I cant wait!
I have the UHPs in 255/55-18 and find there is no noticeable tire noise. Definitely not as loud as the Pirelli Scorpions they replaced, nor the original P Zero 19s, though Pirellis are notorious screamers with a little mileage. Could be your alignment, balance, inflations, or the tire size.
DenverBill is offline   Reply With Quote
Old 06-29-2009   #16
Everything is good to go. Wear could definitely increase road noise. Biggest contributor would be the tire size. You have a lot more sidewall than I do.
General grabber czechT698 Running Gear 24 06-18-2009 06:55 PM
General Grabber AT 2 18" - Practically new set TurboMatt Classifieds 3 06-17-2008 08:43 PM
Parada Spec X or Grabber UHP nickm Running Gear 1 02-09-2008 12:54 PM
Consumer Reports Test UHP Tires hbv2020 General Maintenance & Repair 0 09-28-2007 02:12 PM
Club Touareg on Facebook
