Disc Brake replacement time - Page 3 - Club Touareg Forums
post #21 of 38 Old 02-03-2016
Njord's Avatar
Originally Posted by tobac View Post
Thanks for the information. However according to my vehicle specification plate the front brakes PR # is 1LE. The rear brakaes are 1KF. I am not sure what changes that makes. Cheers.
I used info written in your first post. Again, for 1LE, pads differ 7L6 698 151E. All other components are same.
Njord is offline
post #22 of 38 Old 02-05-2016
Touareg Brake Specialist
Send a message via Skype™ to QPower1
That is the world of difference!!
A 1LE brake design isn't the 1LC pads...
Alretta Truck Parts, Inc.
508-788-9409
"Where Parts are a Science and Service is an Art!"
QPower1 is offline
post #23 of 38 Old 1 Week Ago
Guys what is the best way to figure out which side brake to replace, without taking the brakes apart?
My baby: 1969 300SEL 6.3
TouaregNut is offline
post #24 of 38 Old 1 Week Ago
Moderator
hedditch's Avatar
You are saying "side, which concerns me a little, as brake pads and rotors are normally always replaced as an axle set. Front or rear (or both) not one side at a time.
QPower1 likes this.
2008 V6 TDI, Air Suspension, ACC with Front Assist, Paddle Shifter, RNS510, Leather Seats, BI Xenons, 4 Zone Climatronic, Sunroof, Towbar & Trailer Module,Fiscon Bluetooth. Reversing Camera, Front Fog Lamps Xenon 3000K, Redarc TowPro Brake Controller, T1 Door Warning Lamps, T1 Under Seat Drawer, Alloy Skid Plate, 5ton Winch, Cayenne (Green Dot) Front and Rear Sway Bars, Performance Tune by Oettinger, Retrofitted 6 Piston Brembo Front Brake Callipers, Custom Sports Steering Wheel
hedditch is offline
post #25 of 38 Old 1 Week Ago
X2.
You must replace both sides on the same axle at the same time to maintain even braking performance.
post #26 of 38 Old 1 Week Ago
Sorry guys for the absurd post. What I am trying to ask is there a wait to figure out if I need to replace the pads on the front right or left or rear left or right?
Thanks for the replies though.
post #27 of 38 Old 1 Week Ago
Moderator
hedditch's Avatar
Simply by removing the road wheel, you will be able to see the remaining pad thickness. Outer pads can be seen without removing the wheel however inner pads are more difficult to check.
A couple of points to remember about maintaining decent pad depth;
1. You are pulling up a vehicle weighting over two metric tons ( 2000 kg +)
2. Brake efficiency drops off as the pad reaches minimum thickness due to heating and reduce material mass
3. You will, due to normal brake bias, burn up fronts at about twice the rate of rears, however don't assume that the rears don't need inspection
4. New brake pads ( and even rotors ) are cheaper that panel work !!!
Remember whilst braking, a massive rush of adrenaline is far more enjoyable than massive panel job.
Stuart....
hedditch is offline
post #28 of 38 Old 1 Week Ago
Njord's Avatar
For me, a foreigner, your text is still ambiguous. (I understood hedditch and nooby though). Correct me, if I am wrong, the pads arrive in pairs.
Njord is offline
post #29 of 38 Old 1 Week Ago
Ok let me try again. I just want to know how do I figure out which pads to replace? The brake pad warning light has just come on and I am planning to place the order.
post #30 of 38 Old 1 Week Ago
Perry01's Avatar
Replace all 4 corners.
2008 AUDI A4 S-LINE
2016 GTI 4 DOOR, DSG
Perry01 is online now
