Air Suspension Compressor Rebuild - Club Touareg Forums
post #1 of 18 Old 07-02-2013 Thread Starter
Treetz's Avatar
Second Vehicle: Old heap
I kept getting running gear fault workshop error message followed by air suspension fault. Decided to try a compressor rebuild after reading some of the forums on here. Found a rebuild kit for $30 on ebay from i6automotive to replace the piston seal and o-ring. Easy install and no more air suspension error message.
2004 V8. Air Suspension. 255/65R17 Cooper Discoverer AT3. Replaced Tiptronic Shifter Assembly. Replaced Alternator/Battery B+ Cable. Replaced Headlight Washer Pressure Cylinder. Intake Flap Pivot Cleaning. Gruven Intake Manifold Linkage Arms. Air Suspension Compressor Rebuild. VAGCOM.
Treetz is offline
post #2 of 18 Old 07-02-2013
nikoloz's Avatar
hi treetz, could you post the link for the kit plz. thank you
nikoloz is offline
post #3 of 18 Old 07-02-2013 Thread Starter
Treetz's Avatar
Porsche Cayenne Wabco Air Suspension Compressor Piston Ring Repair Fix Kit | eBay
Treetz is offline
post #4 of 18 Old 07-02-2013
Mina08's Avatar
Touareg: 2006 R5 TDI
great link thanks, can you run me through briefly on the change, i.e. location of compressor etc
Treg-ing addictive as crack but twice as expensive
R5 TDI / Air Sus / BlueFin
Mina08 is offline
post #5 of 18 Old 07-02-2013 Thread Starter
Treetz's Avatar
Compressor is located under vehicle, below passenger front. Put treg in xtra high suspension setting. Hold suspension lock until it is locked out. Remove plastic cover underneath passenger side to get at the compressor (T27 bolts). Disconnect the two compressor electrical connections (small flathead screwdriver). Remove the three bolts holding the compressor support (13mm bolts). Tilt the compressor until you can access the two bolts that connect the two cylindrical bodies of the compressor located at the piston head (T27 bolts). Clean around the junction. Pull the parts apart to reveal the o-ring and the piston head. Take note of the piston seal orientation. Replace the piston seal and o-ring. Button it all back up.
I think you could adjust the amount of play the compressor has and make it run more quietly by adjusting the tension on the isolater spring (wide flathead) while you have it accessible, but I did not think of this until after putting it all back together.
Venom13132 likes this.
Treetz is offline
post #6 of 18 Old 07-02-2013
Mina08's Avatar
Thanks for taking the time to post the info, helps alot.
Mina08 is offline
post #7 of 18 Old 07-09-2013
Mina08's Avatar
Just finished the job took 30 mins again thanks
Mina08 is offline
post #8 of 18 Old 07-09-2013
Great find! Looks simple enough to do! And saves money by not replacing the entire compressor.
I just hope there is an more cost effective way to replace shocks. I always fear that will go on my treg.
'04 V8, Blue Silver, Vin# 29XXX. 18" Manh. Wheels., Nav, Air Susp, & Parking Sensors.
Diablonyc2 is offline
post #9 of 18 Old 08-30-2013
Second Vehicle: 2004 V8
Just ordered the kit myself. I get a very intermittent "Fault Running Gear Workshop" message every so often that comes on with a beep and then goes out only to come on again. Happens 4-5 times on an around-town trip, eventually settles down. Could be the compressor. Could be any of the famously funky VW sensors. For $30, now I can fix the compressor if/when it goes punk.
2004 Wheat Beige Touareg
2002 Black Porsche Carrera
2005 Midnight Blue Porsche Boxster S
2012 Audi Q5
peterbigblock is offline
post #10 of 18 Old 10-15-2013 Thread Starter
Treetz's Avatar
The error is back! Consistently. VAG COM reads a pressure sensor intermittent ground. So disappointed!
I am likely going to try the repair kit that includes the air drier from ECS. Anyone have experience with it?
Treetz is offline
air suspension , compressor , i6automotive
