#21 |
Thanks for the info FixMyBug. It's actually been raining here for a bit today (I'm loving it!!) so I didn't want to delve into this and risk getting something wet.
Osram is listing the 66142 bulb as a 4100k bulb in their literature. This is indeed slightly more yellow than the 4300k that seems to have been the norm for the Touareg. Check here for a PDF of Osram Automotive lighting for more info. Our bulbs are on page 9.17. Matt
#22 |
The higher the color temp the less light you get,the 4300 is the brightest,Marty
#23 |
Illumination
Whiter and crisper blue-white light is safer because it is closer to natural daylight compared to light from halogen sources. Color temperature is ~4200o K compared to ~3200oK for halogen. |
#24 | |
I thought they were higher temp. Cya
'05 VW Touareg V6 Campanella White/Anthracite '02 VW Jetta GLS TDI Galatic Blue/Beige |
#25 |
Stock HID is generally between 4100-4300k. I think some brands may use hotter (over 4300k) color temps, but I doubt they'd go over 6000k if they even go that high, due to the diminishing light. HID headlamps are available hotter than that, but they generally are the "boutique" things that people that want more blue light put in their vehicles. Functionally, they get dimmer the bluer the get, so the higher the color temp the bluer the bulbs appear.
I've seen HID headlight bulbs as high as 10000k, which are really blue. Matt
#26 |
Thanks Matt, all cleared up now.
Cya
#27 |
Everything I've read and been told... the max light output and best white color for xenons is at around 6000...anything above that goes purple and you lose output.
I dunno
2006 V6, Campy White, VIN 46xxx, Anthracite w/ Sound 1 and Xenon Headlight Upgrades, Monster Mats, 3M Window Tint, Euro Headlight Switch, Gorilla Gear Cargo Mat, Clear Bra, VW Tow Pkg, VW V8 Style Exhaust Tips, 18' Manhattans & Silver Racks |
#28 |
My passenger sid ebulb has started flickering.. I have a horrible dealer here also so wondering if they would replace this from the TSB? Does anyone have the TSB so I could call the dealer and ask them? Also the color of the 2 lights has shifted one is mor epurple and the other is bluer and lfickering.
Thanks, Jeff |
#29 |
i had one of my xenons changed under warranty and the color did appear different for a while but almost the same now.
V10 TDI with Sat Nav, paddle shifters, rear diff locks, hinged spare, phatbox ... Had V6 petrol on Pirelli AT's with Sat Nav, Rear Diff locks, Bluetooth & Phatbox. |
#30 |
Mine did exactly this too, the headlight assembly connectors aren't very well designed, just take the assebly out, clear the dust off the connectors with compressed air and bend the pin a little and it will be fine again.
FYI the left sidelight pin is the top left corner pin of the connector on the car looking from the front. Cheers
R5TDI Lux | Col Red - Teak | Satnav | Towbar | Park Sensors | Sunroof |
| Thread Tools | |
| Display Modes | |
| Xenon fog lights!! full Xenon kit from Lexus! | vwtouareg4me | Touareg Mods | 11 | 04-11-2008 04:57 PM |
| Xenon headlight replaced | nvrhome | Problems/Bugs | 5 | 03-04-2007 04:36 PM |
| dealer says I need new brakes, but no brake warning light??? | angelehua | Problems/Bugs | 8 | 10-11-2006 01:38 PM |
| Bi -Xenon Headlights Brights point up. Dealer said can't adj | ScottG | Problems/Bugs | 9 | 01-10-2005 06:24 AM |
Other
Social Knowledge
