TPMS bad sensor - identify which tire - Club Touareg Forums
post #1 of 24 Old 03-07-2007 Thread Starter
I have had a continuous TPMS fault message for the past couple of weeks. The dealer states that it is a faulty sensor. They say they would need to dismount the tires one by one until they find the faulty sensor. They noticed I had relatively new tires and said that it was most likely the fault of the tire store which means it would not be a warranty repair. The store may have damaged a sensor when mounting the new tires. They wouldn't know until they took the tires off. All this seems improbable to me. I replaced the tires 3 1/2 months ago and the TPMS has worked just fine from then up until a couple of weeks ago. It seems likely that if the tire store damaged a sensor it would have shown up on the day of the tire replacement.
Does anyone know if there is a way to identify which tire has the faulty sensor without taking the tires off the rims?
LF IL Touareg is offline
post #2 of 24 Old 03-07-2007
Yeah look in the MFI.
2008 T2
2007 Touareg (Gone)
2004 Touareg (Gone)
2002 LR Freelander (Gone)
mech8882 is offline
post #3 of 24 Old 03-08-2007 Thread Starter
MFI
Did that prior to post. Vehicle status shows "Tire pressure monitoring system fault" When selecting Inflation Info everything checks out ok.
By the way, I have a 04 V8. It has had several problems including TPMS, stepper motor, dead battery, compass flashing, etc. etc. How is your '07 much better than your '04?
post #4 of 24 Old 03-08-2007
Vegas Matt's Avatar
Re: MFI
A lot of voltage related issues (and a host of other "problems" that manifest with low voltage) can be the result of a bad alternator cable or a grounding cable to battery issue, which occurred with a number of '04's. Have you had this checked out? Are you still having troubles with low voltage (dead batteries, consumers messages in the MFI, etc) or has this been resolved? If you're still having issues, what does your voltmeter read while idling, and while driving?
Matt
Bye bye Blue...
Vegas Matt is offline
post #5 of 24 Old 03-08-2007
I think vagcom might show you which wheel is reporting an error.
Head On! Apply Directly to the forehead!
4xMotionTDI is offline
post #6 of 24 Old 03-08-2007 Thread Starter
Thanks Vegas. I had the cable replaced for the second time two days ago. Apparently the first time (approx. a year ago) when they replaced the cable it was with a cable of the same design. There is now a recall with a newly designed cable. That new design was put in this time. Hopefully that will solve the electrical problems. Hooking up a battery charger every few days gets old especially on a high priced SUV.
Still need to find a way to identify which tire has a faulty sensor, assuming their is a faulty sensor. The dealer tech says there is and the only way to find out is start taking tires off. I can't go to him with vagcom without more detail.
post #7 of 24 Old 03-09-2007
A professional tire store can check the sensors with a scan tool. Schrader, KST, OTC, NAPA all make them. You have to let some air out to activate the sensor, then the tool will check battery life and tire pressure. If it won't activate you found the bad sensor. They should last close to 10 years, but I have seen failures, not many, but a few nationwide.
Reed Green 2007 V-10, Nav, Winter Package, Air Sup., Four Zone, Locking Dif, Sirius, llumar tint, Mud Flaps,Tow. Monster mats. TPMS comming soon. Covered dash bin.
MIkeS Panzer is offline
post #8 of 24 Old 03-09-2007 Thread Starter
Thanks Mike. I knew there had to be a better way. I think it is another failure and not the tire stores fault. They deal with TPMS every day and the system worked for 3 months after they put the tires on. Could hitting a curb or similar cause the sensor problem or more likely just random failure?
post #9 of 24 Old 03-09-2007
You can damge the sensors with rocks and curbs. I carry a spare stem with me all the time. Damage of that sort would be visible. I broke one putting air in my tire with a lock-on air chuck. I'm more carefull now. Get a good tire store to check for you. A random failure is not out of the question, but very rare. You might try dropping the pressure 10 Lbs. and refilling to to 40 Lbs. and do a relearn. It might wake it up.
post #10 of 24 Old 03-09-2007
"I DO NOT TAKE ANY RESPONSIBILITY FOR THIS. DO AT YOUR OWN RISK"
My tech once said that if I ever have a problem with one of my sensors. Run the truck up to 100mph for a few moments. It might take a few runs but it should reset the sensors.
2008 T2
2007 Touareg (Gone)
2004 Touareg (Gone)
mech8882 is offline
Identify Rims Schutzen Brakes, Steering, Suspension, Wheels and Tires 5 01-17-2007 11:52 AM
Can you identify this part? PiL General Maintenance & Repair 4 01-12-2007 04:50 PM
Can someonme identify these as well? mech8882 Brakes, Steering, Suspension, Wheels and Tires 2 11-28-2006 06:24 PM
Spike in tire exposes other issues with TPMS.....help GordoG General Maintenance & Repair 1 10-01-2004 10:02 AM
can you change wheels and still use the tire pressure sensor Frozenpeaz Brakes, Steering, Suspension, Wheels and Tires 17 06-12-2004 07:18 AM
