Timing Belt - Club Touareg Forums
post #1 of 29 Old 05-23-2007 Thread Starter
Timing Belt
Just took the 04 Touareg in for the 80K service, they want to change the timing belt for $1200.00. The car has 83K on it, and I will be keeping the car until 100K and then get a new car. Has anyone been told this? Does anyone have 100K on there car? By the way no complaints of motor problems they just want to do it as prevenitive maintenance.
bkosaian is offline
post #2 of 29 Old 05-23-2007
TREGinginCO's Avatar
The owners manual clearly states the timing belt is to be replaced at 80k.
2013 Audi allroad: Ibis White with Layered Oak Inlays
TREGinginCO is offline
post #3 of 29 Old 05-23-2007
The Moderator!
Yeti's Avatar
Trust me on this, do it before it breaks. I had a friend who just lost his on his Passat. It cost him almost double that for he needed head work when it went out. So as they say, pay a little now or a lot later!!
Yeti is offline
post #4 of 29 Old 05-24-2007
The timing belt (why the hell do foreign car manufactureres still use belts? They should be chains, they'd last pretty much forever!!) connects the crankshaft to the camshaft(s). If the belt (or chain) breaks, the cams will be out of time with the crank, causing the valves to hit the pistons, breaking them, bruising the pistons, breaking the rocker arms, and pretty much obliterating the entire top half of the engine. The entire engine will need to be torn down, the pistons replaced, and the entire top half replaced (other than the heads themselves). It's pretty labor intensive work (especially on a DOHC engine) and is therefore pretty expensive to repair.
I don't buy $1200 for the timing belt change, though. All they need to do is take the cover off the front of the engine and change the belt and reset the crank timing. Unless the belt is in the back of the engine? Anyone know?
Note to self: sell car before 80k mile service.
2004 Volkswagen Touareg V8
Black with Teak Interior
Everything but OnStar and 19's.
VIN: 86k. Purchased 08/17/2004.
AZBob is offline
post #5 of 29 Old 05-24-2007
LOL.... VW's VR6 uses a timing chain.. What your forgetting is a lot of the time it's not the belt/chain that fails on new cars, it's the tensioners
'05 Treg V8 pkg 3
'03 Golf TDi
'87 Audi 4000CS
Nefarious is offline
post #6 of 29 Old 05-24-2007
The Moderator!
Yeti's Avatar
I buy the 1200 if that is what they want charge. My friend just had his replaced on his Passat 1.8T and it cost him 2600 because he needed head work. I say follow the manual and get it done for a little now or pay a lot more later.
Yeti is offline
post #7 of 29 Old 05-25-2007
Or buy an R5 or V10 tdi, they have gear driven valvetrain.
cheers
V6 TDI 4XMotion
barefoot is offline
post #8 of 29 Old 05-25-2007
BANNED
I do not know for sure but i believe just about the whole front of the car needs to come off to get to it. I know this is the case with the audi and since this is pretty much the same engine.......
nltomba is offline
post #9 of 29 Old 05-25-2007
What's the deal the with the V10 TDI? I thought they need to have the timing belt changed at the same time. I haven't looked at the manual in a while so don't quote me. I had a Jetta TDI 2000 and it needed a timing belt change every 60K. I was a good boy and did that. However on my 120K change, they didn't change the tensioners....cost me a whole new head!!!! I got a fantastic deal with a new head at cost for $1200!!! Not including labor. So, is there something different with the v10 TDI???
My VW timline: '84 Scirroco > '88 Jetta 8v>'89 Jetta GLI> '89 Jetta 8v>'95 Passat VR6> '99.5 Jetta TDI w/ Upsolute chipping...>V10 '06 Touareg
drmark50 is offline
post #10 of 29 Old 05-26-2007
http://www.ricardo.com/download/pdf/..._Benchmark.pdf
Look for V10 tdi and R5 tdi, they are both 'gear driven' valvetrain, no belt, no chain, very robust and low maintenance, but like motorcycle engine with gear driven valvetrains, can get noisy with high mileage (so I'm told).
cheers
V6 TDI 4XMotion
barefoot is offline
Timing belt or chain Godwine General Maintenance & Repair 24 10-13-2007 10:15 PM
V Belt Failure tencjedd General Maintenance & Repair 4 06-03-2007 05:33 AM
Need help replacing Serpentine Belt c5lover General Maintenance & Repair 6 01-25-2007 05:48 AM
Timing is everything... silas Brakes, Steering, Suspension, Wheels and Tires 2 05-14-2006 08:38 PM
Timing Advance Resistor Mod? msiler General Maintenance & Repair 3 10-26-2004 08:35 AM
