Go Back   Club Touareg Forums > Club Touareg Community > General Touareg Discussion
Old 02-19-2004   #1
Jason
Images: 12
Shifting from Park to Drive when on a hill
Can anyone say how to avoid the gearbox 'clunk' I experience when moving from Park when on a hill to Drive or Reverse?
It doesn;t sound very healthy!
I have tried everything from pulling up, putting handbrake fully on, and then shifting into Park - but when I return to move off, the Park gear seems to be very tight and in a way, jammed - moving to reverse makes an awful sound.
Any similar experiences?
1st Treg V6L October 2003 - June 2007 120000kms, 2nd Treg 2007+ V6TDI bixenon, air suspension,tow hitch and wheel carrier, 4 zone climate, VW Satnav v14, Driving lamps, Parrot 3100 bluetooth, factory roof racks
Jason is offline   Reply With Quote
Old 02-20-2004   #2
Makbros
Images: 1
No, I have not experienced this problem, but try this:
When you pull up,keep the brake pedal pressed down and at the same time apply the hand brake.
After applying the hand brake, take your foot off the brake pedal and see that the vehicle is not rolling backwards or foward. If not then put it in park.
V8 Touareg, Off Road Gray,,PP2, Diff Lock, 19" wheels, Anthracite interior
Makbros is offline   Reply With Quote
Smooth shifting? Lindeman Problems/Bugs 24 09-11-2008 07:59 AM
If you didn't drive a Touareg, what would you drive? nickm General Touareg Discussion 65 03-10-2008 04:09 PM
Coding update for TSB 01-05-17 trans shifting Depiry General Touareg Discussion 0 08-22-2006 05:17 PM
New Member - Abnormal shifting and grinding sound flying v Problems/Bugs 3 06-04-2005 04:11 AM
Hard Shifting / Range of Remote V8 ttbone Problems/Bugs 2 08-17-2004 12:25 PM
