Sea Foam For Engine Oil Flush? - Club Touareg Forums
post #1 of 51 Old 07-18-2011 Thread Starter
I've read on here that quite a few have used Sea Foam in their gas tanks with positive results. What about using this stuff in the engine oil, say a few hours before changing out the oil? Any feedback on this?
volkswagendude is offline
post #2 of 51 Old 07-18-2011
V10
V10's Avatar
I can't imagine it would do any harm. I use two bottles in my BMW 750 prior to an oil change and it seems to me to really keep the engine clean. The only 2 cents I can personally provide is put the Sea Foam in when engine is cold - when I put it in prior to an engine oil change I've done so warm and it seems to vaporize as it enters the valve cover and is likely not going to be as effective as when heated up with the engine oil. I add 2 cans due to the large sumps in these vehicles and don't know if that's necessary either...
I also think you could add it a couple of days/weeks prior to oil change as it will remove deposits of varnish better over time than just prior to oil change. Maybe put one in a few days prior when you know you'll be driving for a bit and then another a few hours prior to changing the oil.
Last - I seem to be very chatty today If you change your oil every 5k miles it is unlikely that there would be much varnish with the oil additives now-a-days...
V10 is offline
post #3 of 51 Old 07-18-2011
Senior Trex-Tamer
Ziggymackenzie's Avatar
This is a very interesting topic, I've never actually even thought of doing such a thing. I have prior experience running it through the vacuum lines on my BMW 323 conv. and of course in the fuel with great results to both. I know that you can add it to the oil but I've only ever done so in our older model motor home and only as more of a stabilizer.
I'm about to do an oil change... might try this myself.
Ziggymackenzie is offline
post #4 of 51 Old 07-18-2011 Thread Starter
I just went ahead and bought a couple of cans.....
I think the real question here is, if this stuff is not really needed because the engine is clean to begin with(hypothetically clean), will it hurt at all to use it? Perhaps a bad analogy, but kind of like antibiotics on humans. They all have their side effects, but if you need it, you need it, therefore the advantages outweigh the negatives(the risk) on a scale. Now if you just pop anti-biotics "just to be safe" you are then exposing yourself to the side effects all in vain.
I guess this was my dilemma. I'll give it a shot this once, I've yet to read anything negative on the internet on this product. I'll add a full can in the gas tank, and a full can in the engine oil crankcase. I'm due for an oil change this Saturday.
post #5 of 51 Old 07-19-2011
i posted an article on how to run seafoam through the intake using the vacuum line, a year or two ago, search for it. But it made a significant difference in my case especially having 80k on it.
Never mind, my prior comment as i see your asking about the oil crankcase, i did this as well, it will thin out the oil significantly when you go to drain it. Just make sure you dont drive over 100 miles after pouring it in.
2005 Touareg V8
2006 GLI
2002 Z06
aaks38 is offline
post #6 of 51 Old 07-19-2011
My God,it's full of stars
siberian's Avatar
Second Vehicle: 2008 V6
I used a couple of cans in the gas tank in the hopes of solving the variable intake motor problem. It didn't and I didn't notice it having any effect (good or bad) on my 08 V8
siberian
siberian is offline
post #7 of 51 Old 07-19-2011 Thread Starter
Thanks for that heads up on oil thinning!
V10 do you have any comments on the oil thinning?
post #8 of 51 Old 07-23-2011 Thread Starter
Have an observation to report. I added Sea Foam into the crankcase oil late last night, and took her out for a 25 minute low revving highway spin at about 110-120km/h. Came home shut it off, and checked the colour of the oil on the dipstick after I let it sit overnight and starting her up again to drive it into my garage for a DIY oil change. The colour of the oil was quite light and clear, equivalent to No.1 grade Maple Syrup. I'm surprised to see that it is now about 20-30% darker, which in all likely hood indicates, that the Sea Foam removed and suspended carbon and sludge related particles.
I'm now even more curious to see what the oil filter will look like. In the past, it looked fairly clean, after 10000km(6214miles) of use, ditto for the oil. This engine has always indicated to me that it was fairly clean on the inside in the past, hence why I'm surprised at the initial results. Curious what an oil analysis would have indicated with the Sea Foam in there!
post #9 of 51 Old 07-24-2011
Built4Sin's Avatar
Interesting Volkswagendude, I wonder how the oil change oils going to come out consistency wise. Make sure to post back!
2004 | V8 | SHADOWBLUE | TEAK INT | HID | AIR SUS | TOW | 4-ZONE |
| PUSH START | CAYENNE YELLOW BARS | NITTO G2 265/50r20 | 20" POWDERCOATED Q7 WHEELS
2009 | 335D | V6TT | CRIMSONRED | DAKOTA BLACK INT | MSPORT PACKAGE | COLD PACKAGE | PREMIUM PACKAGE | IDRIVE |
Built4Sin is offline
post #10 of 51 Old 07-24-2011
Senior Trex-Tamer
Did your garage open back up yet? I'm curious to see your findings as well.
New guy foam San Jose,CA CapVW_Treg New Member Introductions 0 12-19-2010 02:46 AM
Oil and Engine Life Bails General Maintenance & Repair 21 08-20-2009 03:32 AM
Engine Oil techartct3 General Maintenance & Repair 2 05-19-2005 07:42 AM
Engine Oil for 4.2L TReg newekkau General Maintenance & Repair 2 08-09-2004 11:34 PM
