Go Back   Club Touareg Forums > Club Touareg Community > General Touareg Discussion
Old 05-25-2005   #1
V10-downunder
Running Coax and Control cable for external HF antenna.
I intend to install a Codan fully tunable HF antenna at the rear of my V10 by using the tow bar as the main mount. Has enyone had luck in bringing cable into the rear of the vehicle without drilling or doing mods? I want to leave it original.
V10-downunder is offline   Reply With Quote
Old 10-25-2006   #2
Arkarch
Arkarch's Avatar
Images: 3
Send a message via Yahoo to Arkarch
Hi, I am involved in similiar projects and curious if you or anybody else has further experience in routing coax.
My current plan is to route coax through the rear pillars accessed from the CD changer / extinguisher access panels. Holes would be made under the hinge cover plastic molding and then routed up the roof where modified Diamond 9000 LRM's await. Some modification to the hinge covers is expected,so I have already acquired replacement hinge cover molding to restore later. All this should work well for the VHF / UHF / Microwave (2.4 ghz) antenna set.
However I am still trying to come up with a good solution for HF antenna mounts and grounding. A local HRO sales person suggested a hatch lip mount near the lighting, but I am still fairly wary of attaching anything directly to the exterior body of the car - plus there is a good chance I would be operating with the hatch up during relay operations. Your idea of tow bar is good, and I have also looked at the tow hook spots, but no upper anchor would be possible. Then there is the issue of grounding body to frame.
What have others done?
2006 V6 Colorado Red + BFG 265/70/17's + Surco Rack + VIAIR + antenna farm
Ham Call KF6VOM -
http://www.mojaverats.com
Photos Offroad - http://picasaweb.google.com/kf6vom
Moab: Hells Revenge, Fins, Tower Arch, Klondike Bluffs, Porcupine;
Big Bear: Gold Mtn, Jacoby, Clarks;
Bishop: White Mtns, Coyote Flats;
Ouray: Engineers, Imogene, Corkscrew, California, Hurricane, Cinnamon, Yankee, Governors;
Vegas: Wheelers, Potato Ridge; Anza-Borrego: Arroyo Seco Del Diablo, Sin Nombre, Oriflame
Arkarch is offline   Reply With Quote
Old 10-25-2006   #3
Vegas Matt
Vegas Matt's Avatar
I haven't done anything like this, but from my hitch install I know there is a soft rubber grommet on the right rear corner near the CD Changer area. If you route it out there, depending on the thickness of the cable, you may be able to run it up toward the roof in the channel where the hatch recesses into the body. Not sure if this would work or not, but just a thought. Good luck!
Matt
Old 10-25-2006   #4
aircooled
Fur Covered Admin
aircooled's Avatar
Images: 5
FWIW, here is VW's official antenna mounting guide:
//06 Touareg V8, Campy White & Teak-Air--DVD NAV--Backup Cam--Kessy--Winter--Xenon--Rear Diff--Factory Tow Package--Dakar Offroad Front Skid Plate
//08 27' Airstream International CCD :: Airforums.com Member - "Westfalia"
//08' Dodge Ram MegaCab 6.7L CTD "The Man Diesel"
aircooled is offline   Reply With Quote
headunit antenna cable Upin96 Mobile Electronics 3 06-08-2007 07:41 PM
Vag Com 607 HEX-USB+CAN Cable step@[dartmouth] Group Buys 14 05-10-2007 04:08 PM
GPS Antenna for Nav. SYR16VGLI Mobile Electronics 6 04-27-2007 11:48 AM
Nav Antenna dogfather Mobile Electronics 3 03-08-2007 03:24 PM
Antenna Part # phybbs Off-Topic Forum 0 12-01-2006 02:00 PM
