Replacing struts - Club Touareg Forums
post #1 of 8 Old 12-13-2009 Thread Starter
Replacing struts
I have about 70k on my v8 treg with non air suspension. Im guessing that my struts probably need to be replaced, has anyone done this and hows the installation? Also is there a way to tell ride wise when the struts are worn.
Thanks cal
aaks38 is offline
post #2 of 8 Old 12-13-2009
Can't be any more different than any other vehicle with a steel spring shock combo. When the vehicle yo yo's up down down after when first pushed down, or when you hit a dip at highway speeds, and it goes up and down more then once, its time to replace.
volkswagendude is offline
post #3 of 8 Old 12-13-2009
My God,it's full of stars
siberian's Avatar
Second Vehicle: 2008 V6
I think aaks38 was actually asking HOW to do it, meaning a write up past the Bentley manual...
siberian
siberian is offline
post #4 of 8 Old 12-13-2009
siberian
Oh, I noticed that all right...but I conveniently skipped to his last sentence.
"Also is there a way to tell ride wise when the struts are worn".
post #5 of 8 Old 12-13-2009 Thread Starter
Thing is many cars nowadays are so stiffly sprung that its so hard to see a lack of rebound in the struts/shocks and see ecessive bounce.
Ive replaced the struts and shocks in my Jetta and was wondering if its similar but noticed there wasnt any writeup yet..
aaks38 is offline
post #6 of 8 Old 12-14-2009
siberian's Avatar
Well time for someone else to be on the bleeding edge
siberian
siberian is offline
post #7 of 8 Old 12-14-2009
AndrieK's Avatar
Touareg: 2004 R5 TDI
It's completely different, but actually a lot easier than a Jetta.
On the fronts, you disconnect the strut from the hub carrier and anti-roll bar at the bottom, and undo the four M8 nuts on the top mount and the whole assembly drops out.
The back is similar at the bottom, but at the top there are four M10x25 bolts that attach the assembly to the subframe, which is a little difficult to access, but not too problematic.
Getting the coils of the dampers is a royal PITA. You need a serious spring compressor.
AndrieK is offline
post #8 of 8 Old 03-27-2011
loose strut mounts...
my car has a constant rattling sound on even small bumps which I was told is a loose strut mount, something having to do with the front right suspension. Other parts were thoroughly checked and OK.I didn't understand why they couldn't just tighten it, nor did I want to pay them $1200+ for new front suspension including new mounts and an alignment.
Seems it's not a safety issue... what's the worst that will happen if I just ignore it on this high mileage (112K) car? I'm planning on keeping it until something major breaks on it.
britannysmoosh is offline
Replacing less than 4 tires IamCharlieJudd Brakes, Steering, Suspension, Wheels and Tires 32 03-21-2016 06:49 AM
New Struts vs. Upgraded Coil Overs TX-T-Reg Touareg Exterior Mods 3 10-30-2009 08:22 AM
Replacing taillights filipposd Touareg Exterior Mods 6 12-20-2008 10:33 PM
replacing speedometer from MP/H to KM/H ravivhaik Touareg Exterior Mods 6 11-08-2008 11:42 PM
Replacing Xenons NC-VW General Maintenance & Repair 1 02-18-2008 04:29 PM
