Overheating Problem - Club Touareg Forums
post #1 of 10 Old 03-25-2012 Thread Starter
Perry01's Avatar
Overheating Problem
I recently noticed that the electric fan runs for a few minutes after I turn off the Touareg so today during a long drive I notice the the temp guage is reading 230 degrees when it is normally between 200 and 210 degrees. The coolant level is fine.
Any ideas as to what may be causing the overheating?
Vag com scan shows a few faults:
Sunday, 25 March 2012, 16:30:49:60350
Chassis Type: 7L - VW Touareg
Address 01: Engine Labels: 077-907-560-AXQ.LBL
Controller: 4D0 907 560 DA
Component: 4.2L V8/5V G 0010
Coding: 0007875
Shop #: WSC 00000
VCID: 68A3D01D1B7D
1 Fault Found:
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
Readiness: 0000 0000
Address 08: Auto HVAC Labels: None
Controller: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0020020
Shop #: WSC 21024
VCID: 351D49691C4F
1 Fault Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - - - Intermittent
Address 09: Cent. Elect. Labels: 7L6-937-049.LBL
Controller: 7L6 937 049 K
Component: 2702
Coding: 0100444
Shop #: WSC 21024
VCID: 44FB24AD4795
2 Faults Found:
000 - -
01520 - Rain and Light Recognition Sensor (G397)
Address 22: AWD Labels: None
Controller: 0AD 927 755 AB
Component: TRANSFERCASE 0094
Coding: 0000000
Shop #: WSC 00000
VCID: 7B899F517AEB
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.LBL
Controller: 7L6 919 044 C
Component: DACHDISPLAY 0529
Coding: 0000000
Shop #: WSC 00000
VCID: 370143610643
1 Fault Found:
02607 - Control Module (Relay?) for Aux. Water Heater (J737)
End --------------------------------------------------------------------------------------------------
2008 AUDI A4 S-LINE
2016 GTI 4 DOOR, DSG
Perry01 is offline
post #2 of 10 Old 03-26-2012 Thread Starter
Perry01's Avatar
Water pump?
Any ideas?
2008 AUDI A4 S-LINE
Perry01 is offline
post #3 of 10 Old 03-26-2012
Moderator
hedditch's Avatar
Perry,
Are all the faults current, do they return after being cleared?
Stuart..
2008 V6 TDI, Air Suspension, ACC with Front Assist, Paddle Shifter, RNS510, Leather Seats, BI Xenons, 4 Zone Climatronic, Sunroof, Towbar & Trailer Module,Fiscon Bluetooth. Reversing Camera, Front Fog Lamps Xenon 3000K, Redarc TowPro Brake Controller, T1 Door Warning Lamps, T1 Under Seat Drawer, Alloy Skid Plate, 5ton Winch, Cayenne (Green Dot) Front and Rear Sway Bars, Performance Tune by Oettinger, Retrofitted 6 Piston Brembo Front Brake Callipers, Custom Sports Steering Wheel
hedditch is offline
post #4 of 10 Old 03-26-2012 Thread Starter
Perry01's Avatar
I will clear them before going to work today and check them again after I get there.
2008 AUDI A4 S-LINE
Perry01 is offline
post #5 of 10 Old 03-26-2012 Thread Starter
Perry01's Avatar
The first 2 are still there:
Maybe it's the thermostat. No coolant overheat message though.
2008 AUDI A4 S-LINE
Perry01 is offline
post #6 of 10 Old 03-26-2012
Touareg: 2009 V8
Noticed that your truck is an 04. The brake vacuum hose from the electronic pump to the booster becomes brittle over time - specially the angle and "T" joints. They will crack resulting in a vcauum leak. Another tell-tale sign is the consistent "running" of electronic pump (humming when brake pedals are depressed).
It would have been a quick fix if VW sold the hoses and fittings separately unfortunately, they are in kits. I think a total of 3 sections at around $90 per section.
Check the lines to see if you can find cracking. Good Luck!
rarod58 is offline
post #7 of 10 Old 03-28-2012 Thread Starter
Perry01's Avatar
Took it in to the dealer and was told the thermostat was stuck. Extended warranty to pay for the repair and it's not cheap!
While they are in there, I am paying for a new timing belt, water pump and tensioners out of pocket since the warranty company is paying for the labor.
2008 AUDI A4 S-LINE
Perry01 is offline
post #8 of 10 Old 03-29-2012
Very sensible precaution.
post #9 of 10 Old 03-29-2012 Thread Starter
Perry01's Avatar
Yep, only 56,000 miles on the odometer but the timing belt is 8 years old.
2008 AUDI A4 S-LINE
Perry01 is offline
post #10 of 10 Old 03-29-2012
Well in on miles, well out on time!!
Overheating coolant Zfj220 General Maintenance & Repair 3 12-30-2011 12:43 AM
treg overheating gqjeff General Maintenance & Repair 21 07-28-2011 08:20 AM
Coolant Overheating Pavan General Maintenance & Repair 3 05-03-2011 04:50 AM
Coolant overheating Issue TauntonReg General Maintenance & Repair 18 09-28-2010 11:29 AM
First major problem in 54k miles (overheating) Nefarious General Maintenance & Repair 39 01-10-2008 09:20 PM
