if I am reading your posts correctly, the "8" is gas driven and doesn't come in a diesel. The V10 (TDI) is diesel and may be what you are referring to.
You could look for a 2009 used V6TDI (probably nearly non-existent). The V10s would be easier to find used and slower depreciation (as are the V8 models). The V10 will get you 20-22mpgs average mpgs. Long trips usually 24 mpgs with the V10. You could also delve into the "green" realm of bio-diesel with the TDIs. However, simple maintainence like oil changes (easy on the V10), sounds like you would probably want to take to VW if you aren't interested in doing it. It takes 12 quarts of oil per change
Whatever you get, if you are worried about problems and the financial stretch, purchase an extended warranty (10years/100k miles) and hold on to it. I honestly can not think of a vehicle I would prefer to have over the touareg (regardless of the powerplant)!! They are classy, powerful, and fun to drive
Chuck
2006 Campy V10, 2005 Passat TDI, 2001 Jetta TDI
