Headlight replacement costs? - Club Touareg Forums
post #1 of 23 Old 06-17-2007 Thread Starter
I just had the "CHECK LIGHTS" warning come on and sure enough the rightside, outside light is out. How much to get fixed....anyone have to do this??
Rondude
Ron McLemore is offline
post #2 of 23 Old 06-17-2007
Mine was replaced, under warranty at the dealer.
2004 V6 - VIN 76XXX - Colorado Red and LOVIN IT!
blondee is offline
post #3 of 23 Old 06-17-2007
The bulb is about $225 from a VW dealer. The last time I checked (about 8 months ago) it was not available aftermarket.
If you know how to remove the headlight assembly, it is not difficult to change the bulb yourself.
There is a tool in the on-board kit which is used to unlatch the over-center lock holding the light assembly in. (All it is, is a 6mm socket.) Turn the over-center lock GENTLY counter-clock-wise until it pops. It will be loose and rotate freely about 3/4 turn.
Then reach in behind the assembly and push it forward. It will slide about 3 inches forward where it reaches a safety catch, which you can depress with your finger or a screwdriver; then it will slide out. The wiring automatically dis-connects.
Open the rectangular cover (with the lightning bolt) on the back of the assembly and R + R the bulb. DO NOT touch the glass of the new bulb; skin oil will cause early failure.
When you slide the assembly back into it's tracks the wiring connecter will automatically line up. Once it is fully seated, push in on the front glass of the assembly, so that it will be easier to lock it, and rotate the over-center lock GENTLY clockwise until it pops into place.
CAUTION: The over-center lock will break if you apply too much torque. Go easy and listen for the pop. The right one unlocks counter-clock-wise and locks clock-wise. The left one is opposite: it unlocks clock-wise and locks counter-clock-wise.
A search of the site should get you more info and possibly some photos.
Look in www.files.mytouareg.info
737 Jock is offline
post #4 of 23 Old 06-18-2007
TREGinginCO's Avatar
If it's your xenon bulb and you're still under warranty... it's a free fix.
2013 Audi allroad: Ibis White with Layered Oak Inlays
TREGinginCO is offline
post #5 of 23 Old 07-03-2007
I encountered the "check lights" warning last month. the left front was
out but the whole plastic assembly seemed to be loose. I pushed it back
in and it seemed to latch in place and then the lights came back on
2004 V10
Rich is offline
post #6 of 23 Old 07-03-2007
Rickanns's Avatar
Like Rich, my 04 headlight assembly came loose more than once. Aircooled even complained that I kept winking at him on a couple of off-road trips.
Check that first.
Rick
07 Touareg, V6, Air Suspension, Nav, Locking Diff, Towing Pkg
Rickanns is offline
post #7 of 23 Old 07-03-2007
Rickanns's Avatar
Check that first.
Rick
Sorry for double post....CT gave me error on first try but took it anyway
Rickanns is offline
post #8 of 23 Old 07-03-2007
Rickanns's Avatar
Check that first.
Rick
Rickanns is offline
post #9 of 23 Old 08-15-2007
$ 248.52 In Canton, Oiho, ouchh.
JPARSONS is offline
post #10 of 23 Old 08-15-2007
If it is not xenon it will cost about 10 bucks and take 10 minutes to replace using the procedure from 737 Jock.
If I recall it is a H7 bulb.
2005 Reed Green V6
DesertT-REG is offline
Headlight ? Gator2006 Touareg Exterior Mods 7 07-19-2007 01:59 PM
ACCESSING THE PASSENGER SIDE HEADLIGHT (BULB REPLACEMENT) no03330 General Maintenance & Repair 0 07-13-2007 07:28 PM
maintance costs touareg-cayenne? johnsc2 General Maintenance & Repair 4 06-07-2006 11:00 AM
How do you get AT the headlight bulbs? shbecker Touareg Exterior Mods 3 05-09-2005 11:38 AM
Headlight out! hjimzafVW General Maintenance & Repair 6 05-25-2004 04:11 PM
