Go Back   Club Touareg Forums > Club Touareg Technical Forums > General Maintenance & Repair
Old 4 Weeks Ago   #1
Headlamp connector?
Can someone please tell me how to release the locking tab on the connector on the rear of a T2 light housing? I have the headlamp housing hanging but cant pull the connector off. Its driving me nuts that i cant figure it out and its right there.
Thanks!!!
touareg09 is offline   Reply With Quote
Old 4 Weeks Ago   #2
siberian's Avatar
If you're referring to the wiring connector between the bulb and bulkhead, it's tabbed. Press and it should release.
If you mean the housing itself, there's a plastic lever you need to swing out and once loosened from its anchor you wriggle the housing out.
siberian
siberian is online now   Reply With Quote
Old 4 Weeks Ago   #3
The housing comes right out, its the main power plug in back of the housing the runs all the bulbs that I cant release.
Old 4 Weeks Ago   #4
I don't know if the T2 is the same as the T1 (I imagine it is), and I'm not sure which harness you are looking at releasing. If its the stationary one that the light fixture slides into, mine more or less just lifted out without much trouble, it seems like it works best if you raise one side sooner than the other, I didn't really have to click any tabs but it stays firmly in place when I put it back in.
If you are looking at releasing the connector behind THAT, you have to release the little tab on it, then the harness slides sideways (not up). My driver side slides towards the engine bay, I haven't done the passenger side.
Hope that helps -
2005 V8
frashr is offline   Reply With Quote
Old 4 Weeks Ago   #5
siberian's Avatar
If you could take a picture that would help. The T2 is NOT the same as T1s.
siberian
Old 4 Weeks Ago   #6
Oh, thanks Siberian - good to know. I'll chime out of the T2 wiring chat! LOL
2005 V8
Old 4 Weeks Ago   #7
siberian's Avatar
No, what I meant was that the assembly and connections is totally different so I assume that the wiring is also. But we seem to be trying to understand what exactly he's after so I suggest in the era of iPhones etc. that he reach out and snap one so we can understand what he's asking for. I can't remember having any problems dismantling the headlights...
siberian
Old 4 Weeks Ago   #8
Thanks guy's but I did finally figure it out. I found another engine connector that was similar and easy to get to. Once i figured that one out the same procedure worked on the headlamp connector.
Siberian, just finished my HID install. I slit the original clips and reused them. Clipping in the new bulbs was a bit more difficult then I thought but pulling the headlamp housing helped a lot. I am still a little concerned about the how the clips locked in. They don't work as well once cut.
Otherwise the system works great.
Old 4 Weeks Ago   #9
siberian's Avatar
That's the only way as cutting the wire, as was suggest by some idiot with chinese bulbs is not to be done.
The clips should lock in the same, make sure you have the bulb oriented the right way and the the clips are well locked. You do NOT want those things springing loose.
siberian
Headlamp Bracket problem TorpedoJuice General Maintenance & Repair 4 10-02-2009 12:08 AM
help!!what would you do to a leaky headlamp?? W84ever Troubleshooting & Bugs 8 06-14-2009 03:42 PM
Is the purple connector the vag-com connector? hammick General Maintenance & Repair 1 12-17-2007 02:10 PM
Does anyone know how to change the Headlamp jdominek Touareg Mods 3 08-03-2004 10:05 PM
headlamp washers drsouus Troubleshooting & Bugs 10 02-15-2004 08:28 PM
Club Touareg on Facebook
